Christina, Does it leave water inside the tub? There are a couple of possibilitys. One could be the drain pump. If this fails the wash/rinse cycle will stop as it can sense the water not being pumped out. Can you hear the light sound of a small motot running when it goes into rinse cycle? Listen down at the very bottom far right side or far left side. If you hear the drain pump motor running is there any water discharging out the drain tube going into the wall? You should easily hear the flowing water. If not you have a few possible problems: Drain pump has an obstruction in or around it or, drain pump is actually bad.
In top load washers, if the machine goes through the cycles and then just stops at the spin cycle and leaves you with no noise and a tub full of water more than likely the lid switch is bad and not completing the circuit for cycle to continue. This is a safety precaution to prevent injury by reaching in the machine while at high speed spin. If the machine is getting to the spin cycle and still turning slowly but not draining the water, the pump is probably the culprit, either being locked up or in most cases something like a sock, etc. is stuck in it preventing it from turning. This is usually indicated by a humming sound during the spin/drain section with no water draining.
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
sounds like a blocked drain hose or a faulty pump motor..If the machine can be drained by putting the drain hose lower than the water level then the hose is not blocked and it may be the pump...Make sure the hose leaves the machine from under the tub and not high on rear of washer. Obviously water won't flow uphill..If the pump has failed a new pump motor is much cheaper than buying a whole new pump....Nomess
Drain hose is kinked or clogged the pump filter needs cleaning . always turn machine off when working on it . and donot forget there is always water in filter .so put blanked or towels down.
