Question about Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder
My box sagem pvr 6240 stop suddenly and started to flashing er09, l turned off for 2 hours and when l restart it shows pb03 and change and keeping flashing er09. I have manipulated the buttons, pushing exit/menu, menu/okey and tried to turn off without issue. please could you tell me if my box is dead? please help me, do not have garantie, as the box has more than 2 years
Posted by gichabeur on
    Top Expert:
  • Sagem Master
  • 76,823 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Posted on Sep 07, 2017
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: Problem with my sagem pvr 64160t
Powering on a Sagem 64160t after disconnecting the HDD will produce the problem that you are experiencing. Sagem build quality can be poor. After opening the case, carefully check the data and power connections to the HDD for joints that lack solder or that haven't been properly seated. If the connections are good then the problem lies with the HDD, which may have failed. Unfortunately, DIY Sagem HDD replacement can be problematic.
Posted on Sep 10, 2009
Anonymous
  • 3006 Answers
SOURCE: Sagem 6200T
The Sagem PVR 6280 is specifically listed as a model which will have problems with the retune. Although the Sagem PVR 6200 and 6200t are not specifically listed as problem models they are very closely related to the 6280/6240 models and share most of the same firmware and software.
See the address below for a chart of affected models, you'll need to contact Sagem directly on 0845 0900 316 for either an over the air update or an update DVD depending upon the manufacturer.
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
Sorry I can't provide you with a definite solution but it's very likely that your model is one of those which only Sagem can sort out.
Please return the favour by rating my answer.
Posted on Oct 02, 2009
Anonymous
  • 212 Answers
SOURCE: Er09 and Er07 black screened
Turn off the unit for 15 mins.
Turn back on with eveything connected except the antenna.
You will get an er 09 on the display.
Press OK on the remote.
With a bit of luck the box will reboot into standby.
Connect antenna and see how you get on.
Posted on Jan 11, 2010
Anonymous
SOURCE: Shows ER07 ER09 ER 01
I had a very similar problem. On initially starting up it showed Pb03 then would cycle between er07 er09, er01 and counting up 00,01 up to 19 or so.
Nothing I did fixed it including turning it off for a long period and back on without the aerial.
Eventually I fixed it by pulling out the power cable while it was counting up and then on powering back up it started to initialise correctly. No idea what the problem was and why this fixed it but it might be worth a go. It didn't involve losing any recordings.
Posted on Feb 07, 2011
Anonymous
SOURCE: I have sagem DVR6200T/6400T which is giving me
I have a Sagem 6200T/6400T when changing to another channel the lights went out on the box and I cannot get them back
Posted on Apr 04, 2011
4helpful
Shows ER07 ER09 ER 01 Scrolls through 01 etc. and eventually shows ER09 SAGEM Model DVR 6200T/6400T
When i turn the box on there is a loud `whurring` sound and the box says` Er09` what do i need to do to fix this ?? Thanks
Hi I waent to your forum and followed some advice about the error code and now the box is working .... it was an update issue ... i needed to disconnect the aerial and then leave and then re-connect. Thanks
bren
3helpful
2answers
4helpful
2answers
Hi :-) I also have P603 / Er09 / Er07 / 00-- Error messages, even after being unplugged overnight. Upon power application the unit clicks quite loudly 10 times in a row, then repeats this 4 times, before...
contact sagem 0835 0900316 technical support helpline you will need serial number of your box and the model a new power adapter was all I needed and can now watch all the programmes i had on the disc and thought i had lost
helen april 2010
5helpful
2answers
DVR6280GL-UK. Flashes er07 and er09 after attempt to reset. What do I do to fix it?
See the address below for a chart of affected models, but the official advice is that you must contact Sagem directly on 0845 0900 316 for either an over the air update or an update DVD depending upon the manufacturer.
Sorry I can't provide you with a definite solution but I hope that I've at least reassured you that it's not something which you have or haven't done!
2helpful
I have retuned my PVR 6200t recorder and have lost ITV and Channel 5 and several other channels. Any advice?
I don't know my receiver code, i've tried putting in 1234 and 0000 but the it just keeps coming up with bad code please try again
Your question is listed under Sagem PVR6280 so I'll assume that's what you have. What follows also applies to the 6240, 6200 and 6200t.
There is another default code of 1111, if this does not work then there is a jumper switch inside the box on the main circuit board which will clear whatever code has been previously set back to the default code.
Open the box at your own risk and ensure that you physically disconnect the box from the mains and use an anti-static mat or an anti-static wrist strap. From memory, I think that when the jumper has been altered the box needs to be briefly re-powered and then turned off to allow the jumper to be reset back as it was.
If your box is a Sagem 6240/6260 then DO NOT update it yet as these models are known to be incompatible with the update and will lose some functionality afterwards. The official advice is to contact Sagem directly on 0845 0900 316 to see if they have a fix yet, but the number is clearly going to be ridiculously busy this week at least as thousands of their boxes are affected.
Cut and paste the web address below into your browser for the official line:-
I hope that you have found my answer to be useful and ask in return only that you take a moment to rate my answer.
3helpful
Sagem 6200T
8helpful
Error code 09
Er00 - The software that was available for upgrading was of an older or of the same version as the one already in the digital-box.
Er01, Er02 -The upgrade failed. Some information was missed out.
Er03 - The internal memory is not large enough to receive the upgrade.
Er04 - The signal was disturbed during the upgrade.
Er05 - Wrong type of data was received during upgrade.
Er06 - Not used.
Er07 - Access problem in back-up memory (EEPROM).
Er08 - Access problem in video memory.
Er09 - Can not find any data to do an upgrade.
Er10 - Poor or no cable-TV signal.
Er11,12 - Not used.
Er13 - Unauthorised data signals received by the digital-box.
Er14 - Faulty data signals received by the digital-box.
Pb01 - A problem in the ROM memory is detected.
Pb02 - Memory size is too small.
Pb03 - A problem occurred during start up (initialisation
problem).
Pb04 - Internal communication failure.
PbF9 - Hardware error identified during start-up
From elsewhere on the web:
1. Turn off the unit for 15 minutes to cause a full reset.
2. Turn on the PVR with everything attached except the antenna input.
3. You will get an Er09 on the display. On my PVR there was no output on the TV screen whatsoever (totally black screen).
4. Press 'OK' on the remote (confusing as there is no clue that this is what you should be doing, though Sagem support thought that the PVR should prompt you.
5. The box reboots in standby mode."
Good Luck...
I also see some mention that if the above procedure doesn't work, try pressing "Menu" twice to see if that clears error 09.
Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder Logo
Top Sagem Televison & Video Experts
Joaquim Martins
 Mikey
Mikey
ray gallant
Are you a Sagem Televison and Video Expert? Answer questions, earn points and help others
