Question about Jabra BT350 Bluetooth Headset Headset
Jabra bt350 is unable to be detected with any of the devices
Posted by mahesh_a_8 on
William Thompson
  • 324 Answers
Is headset charged and turned on?
Posted on Feb 14, 2010
Im trying to connect my Jabra BT350 to my blackberry 8520 but my blackberry bluetooth wont even find the device even the Jabra headset is turned on.....i also lost my Jabra BT350 user manual cd and i dont...
The headset has to be in learning mode first for any phone to find it, press and hold the power on button for 8 seconds until the power light comes on and stays on then search for it with your phone, pairing code can be 0000
Aug 29, 2010 | Jabra BT350 Bluetooth Headset Headset
I do not have my manual to sync my bt350 with my new phone how do I do this?
Before you use your Jabra BT350, you need to pair it with your mobile
phone.
1. Put the headset in pairing mode
• Make sure the headset is off.
• Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT350
Follow your phone’s instruction guide. This usually involves going to a
‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the
option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a
typical mobile phone in fig. 5)
3. Your phone will find the Jabra BT350
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’
or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4
zeros).
or go here http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
hope this helps
Jan 30, 2010 | Jabra BT350 Bluetooth Headset Headset
Initialy i had used my jabra bt350 with sony ericson but now it is not getting paired with my present mobile
dude first of all you have to reset the passcode of your jebra bt350 then connect it from your parents mobile.
how to reset----
Press settings/connections/bluetooth/check both boxes; turn on, and make discoverable/click devices tab/turn the jabra off/then hold the ear button till the blue light is solid (not blinking)/click new partnership on the phone/click 0000 for the passcode. it should hook up.
Mar 06, 2009 | Jabra BT350 Bluetooth Headset Headset
Jabra BT350 stopped connecting
BR, I had the same problem with my BT350 and my Razr V3c. I was finally able to resolve the problem by doing the following:
- delete BT350 from device list on Razr
- start Razr looking for device
- put BT350 in pairing mode while phone searching (hold answer button till solid blue light)
- phone will detect BT350 and retrieve name
- select Jabra BT350
- say 'yes' to bond with Jabra BT350
- enter passkey - 0000
- phone will connect with Jabra BT350
May 14, 2008 | Jabra BT350 Bluetooth Headset Headset
Vibration on an ear piece
Press and hold the volume down button, then turn the device on by pressing and holding the call button. Now release both buttons.
Apr 15, 2008 | Jabra BT350 Wireless Headset
Jabra BT350 bluetooth
While the headsetis off, press and hold the power button for 6 seconds. It will first blick the light in several patterns, all in blue. Finally, it will come on solid blue, no blinking. It is now ready to be paired. Once your phone/PDA has detected it, the passkey /should/ be 0000, as in zero zero zero zero. That should do it. Best of luck! :-D
Mar 10, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra Bluetooth Setting
You have to pair the two devices first.
Use your phone to detect other bluetooth devices, when it finds the model Jabra you are using select it. Reset it before you start.
Jan 11, 2008 | Jabra BT350 Bluetooth Headset Headset
Connection prob
Brand New Jabra -BT350 won't work on my Nokia 6102i, I did everything in term of setting my phone properly to paired with the Bluetooth, My Phone Bluetooth light is on, and the device blue light is flashing as well, but it still doesn't work. the phone would ring, I hit the JABRA button to answer it.....still can't answer my phone... Please send your help to me at [email protected]
thank you all.
Nov 08, 2007 | Jabra BT350 Bluetooth Headset Headset
I couldn't get it to pair this morning
From the manual )link below),,,, 1. Put the headset in pairing mode ? Make sure the headset is off. ? Press and hold the answer/end button until a solid blue light comes on. 2. Set your Bluetooth phone to ?discover? the Jabra BT350 Follow your phone?s instruction guide. This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menu on your phone and selecting the option to ?discover? or ?add? a Bluetooth device.* (See example from a typical mobile phone in fig. 5) 3. Your phone will find the Jabra BT350 Your phone then asks if you want to pair with it. Accept by pressing ?Yes? or ?OK? on the phone and confirm with the passkey or PIN = 0000 (4 zeros). http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
Jul 28, 2007 | Jabra BT350 Bluetooth Headset Headset
Jabra BT350 Bluetooth Headset Headset Logo
105 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Mosaub Al Masri
Mosaub Al Masri
Marvin
Marvin
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
