Question about Paradigm Monitor 9 Speaker
Paradigm Monitor 9 v4 tweeter not working.
I have Paradigm Monitor 9 v4 speakers and the tweeter on one speaker has stopped working. How can I test to determine if the speaker has died, or if there is some other problem. Tweeter problem is independent of source....phono, CD, receiver. All connections external to speaker have been checked. I removed the tweeter and the connections to the speaker were good.
Posted by jsensabaugh on
woodzowl307
  • 667 Answers
Speaker is must likely blown. check to see if another tweeter works at that connection.
Posted on Feb 14, 2010
  • 1 more comment
  • Joe G
    Joe G Nov 17, 2014
    I did switch my L& R speakers to prove it was the speaker and not the channel. On the speaker itself, could it possibly be the connection and not a blown speaker?
  • woodzowl307 Nov 19, 2014
    buy a new speaker on Black friday
    I can't believe you have not solved this in 3 years....
2014 dodge advenger radio wiring harness diagram
2014 Dodge Avenger Car Audio Wiring Diagram
Car Radio Battery Constant 12V+ Wire: Red/Brown
Car Radio Accessory Switched 12V+ Wire: N/A
Car Radio Ground Wire: Black
C
Car Radio Antenna Trigger Wire: Gray/Orange
Car Audio Front Tweeter Size: 2-1/2? Tweeters
Car Audio Front Tweeter Depth: 5?
Car Audio Front Speakers Size: 6? x 9? Speakers
Car Audio Front Speakers Depth: 4?
Left Rear Speaker Positive Wire (+): Dark Green/Tan
Left Rear Speaker Negative Wire (-): Dark Green/Gray
Right Rear Speaker Positive Wire (+): Dark Green/Brown
Right Rear Speaker Negative Wire (-): Yellow/Gray
Car Audio Rear Speakers Size: 6? x 9? Speakers
Car Audio Rear Speakers Depth: 4?
I have a pair of Paradigm Monitor 3 V.2 High Def speakers for my front L&R home theater system. On speaker sounds very tinny with no bottom end. On inspection neither the main or tweeter loo
A few questions to help me help you: (1) Does the woofer cone move freely when you use your hands to move it (or do you feel friction)? (2) have you tried swapping the left speaker for the right to rule out the receiver as a cause?
How to Replace a paradigm monitor 9 v6 driver
Are you having trouble removing the driver? Just remove it and replace, keeping track of where the positive (red) terminal is and what cable is connected there. The part number should be printed on the back of the magnet.
Paradigm Pw 2100 Speaker
the amplicator is stop after 5 second play
2answers
2helpful
I lost the treble on both Alesis Monitor 1 speakers. The treble is good on the amp output toward the speakers. I'm thinking they went out one at a time and I didn't realize it until I lost the...
It's probably blown tweeters. But if you want to spend the money on a hipshot guess, try to find the the crossovers somewhere first; then find the readily available tweeters if/when that doesn't work out. Google "alesis monitor one MK2 tweeter".
You could test the tweeters by just removing one non-functional tweeter and wiring it directly to the speaker leads and with REALLY LOW volume containing NO BASS see if it makes any sound, which would prove it does/does not work.
Going forward, if the speakers sound stressed at high volume - THEY ARE. Too much power or too much distortion (overdriven amplifier) will kill speakers.
1helpful
I get no music out of the tweeter
Connect the wires of the speaker to a 1.5 volt battery. Plus wire to plus terminal of the battery etc... Only let it touch the battery for a short time! You should hear a pop from the speaker! Put your ear close to the tweeter and see if does the same. If It doesn't, go inside the speaker and connect the battery direct to the tweeter (disconnect it from the crossover unit that feeds it). If it still doesn't pop it's gone and you will need to replace it. If it does it's the crossover that is faulty.
Tweeters are the first to go when the amp is at high volume. So make certain that the speakers don't have a lower wattage than the amp. If they have you must never turn up the volume very high or you will lose the speaker again.
Paradigm monitor 9 v.5
The more power the better as far as amplifiers go, underpowering speakers causes clipping and burns up voice coils. Having a high power reserve means you have higher headroom for transients, with more power the amp will be able to handle transients better and will not be running at full output all the time in order to get desired volume levels, hence more headroom.
If you want to go with quality go with components, a seperate dedicated high quality amplifier such as a haffler, crest, etc., amps you find powering monitors in studios. It all depends what you want.
My speakers sound flat with no highs at all
I am trying to work out if you have damaged the speakers and amp too.
Have you tried a pair of headphones on the amp? If they sound ok then your amp is fine.
Assuming it is, then speakers have what's called crossover units in side each of them. This splits the sound into three parts. Bass, midrange, treble. The bass is handled by the woofer's, the midrange by a middle sized speaker or or it's combined with a tweeter, which of course handles the treble.
Connecting a 1.5 volt battery across any of the individual speakers will cause it to pop if working. If the speaker then is not getting sound then the crossover unit is to blame.
When you look at the crossover unit, it will have coils and capacitors (non polarised) on it. The bigger ones deal with the bass and the smaller ones treble. If you find a fault say on the crossover of the speaker, for example no treble comes out of it. Then start by replacing the capacitors. Use the same value as on the capacitor and remember they fit any way round.
Paradigm Monitor 9 Speaker Logo
Top Paradigm Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you a Paradigm Audio Player and Recorder Expert? Answer questions, earn points and help others
