Question about AT&T Cell Phones
Blackberry 9000 bold, won't power up
Blackberry 9000 bold, screen displayed ''standby mode, press Mute'' I do not know where the mute key is, then the screen went black, I R&R'd the battery, never powered up, plugged in the charger, no change, swapped to my spare battery, same thing, phone dead, no power, no red led indicator when you install the battery, no charge indicator when the charger is plugged in.....phone's only 3 weeks old....
Posted by puddaljmpr on
5 Related Answers
Anonymous
  • 464 Answers
SOURCE: BLACKBERRY BOLD 9000 WHITE SCREEN ON START UP
Your going to have to contact your phone company about it considering it is a software issue. They are going to have to replace or exchange your phone for a new one, or direct you to a technician who can most likely help you out. Sorry your having so much trouble, hope i've helped.
Posted on Mar 19, 2009
Anonymous
  • 32 Answers
SOURCE: unlock code for blackberry
http://store.payloadz.com/details/detail_442315.html
Posted on Aug 03, 2009
Anonymous
  • 75 Answers
SOURCE: Phone is not allowed MM6 in Blackberry bold 9000
Your phone has been blacklisted from whatever carrier you're trying to use. The solution is to unlock (go to www.unlockbb.com if it's not unlocked already) and try another carrier.
Posted on Dec 22, 2009
creative_fix
Abbas John
  • 395 Answers
SOURCE: find imei bold 9000
Just dial this on your blackberry *#06#.
This would display the IMEI number on your screen.
Kind Regards
Posted on Mar 16, 2010
May someone please send the service mode specifications for a Samsung LED 40 inch TV UA40EH5000R?
I don't have service mode specifications but I do have a Samsung and looked around for how to get it in service mode some time ago because the HDMI cables somehow disconnected themselves a lot. Thought it was an electronic problem but it turned out to be a parenting problem instead SO I have never used this information and can not vouch for it. I cut and paste it from a note I copied from a forum entry to use at your discretion:
First post:
To enter "Service Mode" Press the remote - control keys in this sequence :
From Standby Info-Menu-Mute-Power On
- The buttons are active in the service mode.
Remote - Control Key : Power, Arrow Up, Arrow Down, Arrow Left, Arrow Right, Menu, Enter, Number Key(0~9)
Careful though there are things you shouldn't touch in this menu.
avforums.com/forums/lcd-led-lc­d-tvs/601553-samsung-service-m­enu-research.html
Another post:
Method 1
Put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu.
Method 2
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
Method 3
With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Method 4
With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
Method 5
With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote.
Method 6
With the TV in standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.
Samsung LCD Monitor Service Menu Instructions
End quote.
Good luck. Just a basic suggestion you probably don't need: keep track of any changes made by writing them down so you can put it all back if you have to.
Dec 20, 2014 | Samsung Televison & Video
How do i change how i receive text messages on blackberry bold
Click message icon on home screen and press bb logo key.....all your messages will display...
Jun 18, 2014 | RIM BlackBerry Bold 9000 Smartphone
Samsung tv (EURO MULTI) sarvice code
Hello
These are the service modes for Samsung. Check it with.
[1]
Turn on the TV on and select the input that you want to adjust.
# Turn the display off
In quick sequence on the remote press:
{MUTE} {1} {8} {2} {POWER} buttons.
# The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
# Select the function and use the {VOL+} button to enter.
# Save settings and exit by pushing {MUTE} twice then {POWER}.
[2]
With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
Press the {POWER} button to exit the Service Menu.
[3]
Use the {CH+} {CH -} buttons to select items.
Use the {VOL+} {VOL -} buttons to adjust.
Jun 25, 2011 | Televison & Video
What to press for Mute key
While not in a call, simply press down on the volume keys (the first set of buttons on the right side of the handset) until the sound is off (this mutes actions like playing videos, apps, et cetera).
If you're trying to silent the ring, then highlight the speaker/sound icon on your handset's homescreen, select it with the optical trackpad, and scroll down to select the option "silent".
If you're in a call and you want to mute it so that the person on the other end of the line cannot hear you, there are two options: first you may select the mute option on the screen itself by highlighting it with you trackpad and selecting it. The simplest way, in my opinion would be to use the button located on the very top of the handset, to the right side. Depress this during a call, it's very easy and the screen will display whether or not this was successful.
Feb 19, 2011 | RIM BlackBerry Bold 9700 Smartphone
My Blackberry is on standby mode. It says to Press the Mute key to exit. Where is the mute key?
The Mute key is on the top of the BlackBerry, on the right side. You can also hold down the End key for a second or two to come out of standby mode.
Jul 07, 2010 | RIM BlackBerry? Tour 9630 Smartphone
My BB 9000 doesn't turn on. A red light is flashing for a while and then disappear. A remove the baterry but it doesn't work. A connect the BB to my laptop and the red light appear flashing again.
Remove the battery place it back in and charge the battery for a while. After doing this press the standby key that's found on the top corner edge of your BB 9000. Switch the blackberry on and press the standby key once more. This would solve the problem.
Regards
Mar 28, 2010 | RIM BlackBerry Bold 9000 Smartphone
My blackberry says ''Entering standby mode.Press the mute key again to exit standby mode.'' Where is mute key?
The mute key is on the top of the BlackBerry, on the right side. It's not raised at all, so it's hard to see, but if you look at the top of the BlackBerry you'll see it -- it looks like a speaker with a line through it.
Feb 09, 2010 | RIM BlackBerry? Tour 9630 Smartphone
Toshiba 42h82
1. ENTERING TO SERVICE MODE
MUTE
S
(Service mode display)
3) While pressing the MUTE button,
press MENU button on TV set.
2) Press MUTE button
again to keep pressing.
1) Press MUTE button twice
on Remote Control.
2. DISPLAYING THE ADJUSTMENT MENU
1) Press MENU button on TV.
Adjustment mode
Press
Press
Service mode
Item
S Data
3. KEY FUNCTION IN THE SERVICE MODE
The following key entry during display of adjustment menu provides special functions.
Screen adjustment mode ON/OFF: TV (ANT)/VIDEO button (on TV)
Selection of the adjustment items : Channel s/t (on TV or Remote)
Change of the data value : Volume s/t (on TV or Remote)
Adjustment menu mode ON/OFF : MENU button (on TV)
Initialization of the memory (QA02) : RECALL+Channel button on TV (s)
Initialization of the self diagnostic data: RECALL+Channel button on TV (t)
“RCUT” selection : 1 button
“GCUT” selection : 2 button
“BCUT” selection : 3 button
“SCNT” selection : 4 button
“SCOL” selection : 5 button
“TNTC” selection : 6 button
Convergence adj : 7 button
Self diagnostic display : 9 button
Oct 21, 2008 | Televison & Video
Cell Phones Logo
96 people viewed this question
Top AT&T Cell Phones Experts
Ekse
William Alequin
Muntejaya Ginting
Muntejaya Ginting
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
