Kodak ZD710 Digital Camera Logo
Posted on Feb 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't use 4GB SD card
My camera won't work when I insert 4GB SD card
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
146
Points
You must format the card in a computer first, then insert into a camera. I had the same problem. It takes a while for it to read a 4 gb card as well, so be a little patient once you format it and insert it into the camera.
Anonymous
Level 2:
Sniper:
  • Expert 109 Answers
  • Posted on Feb 14, 2010
Anonymous
Expert
Level 2:
Sniper:
Answers
109
Questions
11
Helped
275962
Points
312
Does it work when you insert any other SD card?
1 Related Answer
Anonymous
  • Posted on Jan 30, 2010
SOURCE: my camera wont switch on when i insert my 4gb sd
when i insert my sd card does not work
1helpful
Camera refuses to work with sd card in
What model Praktica camera? Is it compatible with SDHC cards or only with SD cards?
Mar 31, 2013 • Cameras
1helpful
How do I format a SD card in aKodak V570 digital camera
Make sure you have an SD card. If your card is 4GB or larger then it's actually an SDHC card and won't work in your camera.
1helpful
Vivitar itwist610dvr won't save files to my sd card
Unless you've found a VERY rare 4GB SD card, your 4GB card is actually an SDHC card. The 610 will not work with SDHC cards. Try using an SD card, 2GB and smaller.
Aug 16, 2012 • Cameras
I bought a 4gb memory (Sony) card. I t shows unsupported when turned on , is it compatable?
The M415 works with SD cards. Your 4GB card is actually an SDHC card and won't work with the camera. You need to use SD cards, 2GB and smaller.
1helpful
2answers
Im using an optio s4 camera and just bought a 4GB SD card. But when I insert the SD card into the camera, there's only a black screen when I turn it on.:( But when I remove the SD card, the camera works...
The Optio S4 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to go with cards 2GB and smaller.
3helpful
Memory card Sandisk 4GB gives error memory card
The S50 uses SD cards. Your 4GB card is actually an SDHC card, and will not work in the S50. You will have to confine your choices to cards 2GB and smaller.
1helpful
2answers
New digital memory card inserted and camara reads memory card error
1. Try to format your memory card using a PC/Laptop.
2. Now, insert it in camera and check whether its working!
please rate this advice if it helps....tc! :)
4helpful
Inserting either a 4Gb or 8Gb SD card results in a "Memory Card Error".
The S4 accepts SD and MMC cards. SD cards max out at 2Gb. The 4Gb and 8Gb cards are actually SDHC (Secure Digital High Capacity) cards, not SD cards, and thus will not work in devices designed for SD cards. Compatibility goes only one way--SD cards will work in SDHC devices but not the other way around.
New 4gb sd card will not work. card error
Is the slide switch in the unlocked position? Are you formatting it in the camera? Are the card contacts dirty?
2answers
My camera wont switch on when i insert my 4gb sd card
Memory card support : SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
Pls. use the supported SD card.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
