How do I hook up a nintendo wii to 604 via component wires.
There are several ways to do this. Here are the two most common.
The best results will be provided by connecting the component cables directly to your TV, including the audio cables of course, and then connect a separate pair of cables from the TV "audio variable out" to the audio in on the receiver.
However, if you do not have that option then connect via component to your 604 to inputs on the panel labeled "component video in." Then, connect from the monitor out section of the 604 via component to your splitter, cable box etc.
But again...the BEST option is to connect directly to the television as that method provides the least amount of signal loss and you only need one additional set of cables for audio to connect from the TV to the receiver instead of an additional set of component cables which are often more costly.
