Oven pad shows "Err 0E" what does that mean?
SOURCE: Wolf wall oven error message: RTD Open
RTD is resistence tempature detector. The oven is telling you that the tempature probe circuit is open. The temapture probe may have been damaged due to the self-cleaning cycle or it could just be the wiring harness is loose. You will need to remove the tempature probe and test it with a ohm meter. The average reading should be aroun 1200 ohms at room tempature. If it is testing open or the ohm reading is way off then you will need to replace the tempature probe. If it is testing good then it could be aproblem with the control board.
SOURCE: I tried to auto clean bottom oven. Showed err
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
SOURCE: Wolf Range model # DF364-C-LP.
According to the service manuel for this unit you will need to replace your controller, somehow you lost communication. Part number you will need is 806827.
Before you order this I would locate you local dealer or call Wolf and look into the warranty status, this repair should be done by a certified technician.
Call 888-833-0306 this is a distributor of Wolf and can get you the part you need, or 1-800-919-8324 for factory assistance to get this problem taken care of or direct you to a servicer in your area.
This part is pricey, and not easy to have changed out. I have changed one before and is tricky to work with the bullnose on this unit.
I know this information is not what you wanted, but at least I and able to direct you in the correct direction to repair this problem.
I hope this was helpful
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Testimonial: "Quick and very helpful advice"
