Question about HP Compaq Presario V6000T Notebook
TURNS ON AND POWER TURNS OFF RIGHT AWAY.
EVERYTIME I TURN ON MY LAPTOP THE MONITOR COMES OUT BLANK. TURNS ON AND POWER TURNS OFF RIGHT AWAY.
Posted by gus_7890 on
Anonymous
    Guru:
  • 243 Answers
Is the battery fully charged? If so unplug the device before turning it on. My roomates HP will shut off if plugged in while powered on it is most likely due to the compound on the heatsink.
Posted on Feb 13, 2010
Monitor won't come on when power on
Try unplugging it and then plugging in again, and make sure the monitor is turned on.
Apr 20, 2013 | Acer Aspire 5600 Series 5630-6951 Laptop
My LG Flatron W2453SQ monitor is connected to my laptop. Since two days ago, when I dont touch the keyboard/mouse for 30 secs the monitor goes blank and enteres power saving mode. I have chyecked the cable...
HI kissakiwi,
In the control panel's power option , you need to change the SYTEM STANDBY settings to never , and then the problem would be solved.
There are three options , turn of monitor, turn of hard disk and , system standby , if you select all of these three to 'never' then you won't have this problem.
Remember you can also change the settings via the screen saver tab when you right click and select properties on the desktop.
Let me know in case you have any queries. Hope this helps ...:)
Jul 01, 2011 | LG 22" FLATRON LCD Monitor
How to troubleshoot my advent4211c for it to connect to a wireless internet network
First turn wifi on using functions keys (I think Fn+F11). A little icon will show at the bottom right task bar which will have a picture of a pc monitor with a red X symbol. Right click on this and select View available wireless neworks. Once you have that, you will see what you can connect to and simply connect. Please remember that you will always have to turn wireless on using the function key everytime you start your laptop again because for power saving it switches it off everytime you turn your laptop off
Jul 11, 2010 | Advent 4211c Notebook
Acer Aspire 5920G BLANK SCREEN
First of all you have to determine if the problem is the GPU (graphics processing unit) or a possible bad connection on the inverter.
To check this you will need to plug an external monitor to the laptop and use the keyboard toggle to switch screens, usually its hold down Fn and press F6 or the F key with a monitor icon on it.
If the external monitor comes on then the problem maybe the inverter.
To check this remove the screen bezel (plastic screen surround). At the bottom of the screen you will see an elongated piece of circuit board with wires coming from either end covered by frosted plastic.
That is the inverter, check the connections on the inverter (both sides) and power the laptop up to check the display, to remove it gently pull the plugs from each end and remove the screw from the middle and pull the board away.
Look on the back of the inverter itself for a copper coil, if you re-solder the solder points around the coil you may find it works again as components that suffer from extreme heat the solder joints dry causing bad connections, re-floating the solder solves the problem in 90% of cases.
Good luck.
Sep 14, 2009 | Acer Computers & Internet
MONITORS TURNS BLANK OCCASIONALLY AND THEN COMES SPONTANEOUSLY BACK TO NORMAL. ONCE THE IMAGES STARTED FLICKERING. I HAVE THE IIMPRESSION THAT THE MONITOR NEEDS TO "REST".. THE TURNING BLANK HAPPENS...
it seems to be the power management
right clik on desktop click properties
click on screen saver tab
and from there click on power
ther you can adjust monitor stanby mode
Jul 24, 2009 | Computers & Internet
My HP Pavillion laptop turns on but the screen doesn't show.
You could be expierencing a problem with your monitor screen. try this.... connect another monitor screen to the VGA port of your laptop. Now try booting up. Look for and push Fn + the key that turns on a secondary display. if the monitor screen comes on. you need
another laptop monitor. At least you can use your laptop with the second monitor for now.
Jun 16, 2009 | HP Pavilion dv9000z Notebook
Problem with Toshiba Laptop A215-S7437
If you go into control panel and check out your power options. Make sure that your system is set to never shut off the monitor. This will of course waste battery power (if you run off battery) so you will have to decide which is best for you.
If the power settings are not to blame then maybe you do have a hardware issue. Some laptops have a hotkey combination that if coincidentally you are typing and you press the right key combination you send it into hibernation. You can check this via the power settings.
Mar 20, 2008 | HP Pavilion dv6000z Notebook
Screen STAYS BLANK
check your system unit to make sure the problem is not from the system unit
the signal stage and cable is more likely to have faults contact a local technician for confirmation
Nov 27, 2007 | Star Logic 17" LCD Monitor
Hp flat screen monitor
It's probably your dc power supply.
Mine would blank just 2-3 seconds after power-on.
I pulled this monitor out of the garbage - someone threw it away. I found any old 12vdc power supply I had laying around (1 from an hp scaner 1250mA, another rated at 600mA) neither could supply the current (amps) required to run the backlights, therefore backlights shutdown, monitor goes blank--monitor stilled powered on, but black.
I tried all of the disassembly, re-solder various solder joints on the LCD Inverter board and removing the heat/magnetic shield from inside the back cover of the monitor. Nothing worked.
I bought a Segate 80gb external hard disk drive that came with a 12vdc power supply, looks like a typical laptop power supply, rated at 3A (3000mA). Plugged it to the monitor, it powered up, and it works flawlessly.
Oct 19, 2007 | HP Pavilion F1703 17" LCD Monitor
HP Compaq Presario V6000T Notebook Logo
944 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
