KitchenAid K45SS Classic Stand Mixer Logo
Posted on Feb 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I replace a damaged power cord on my KitchenAid stand mixer, Model #K45?
Anonymous
Level 3:
  • Master 421 Answers
  • Posted on Feb 21, 2010
Anonymous
Master
Level 3:
Answers
421
Questions
0
Helped
246432
Points
1123
Firstly get a new cord. Then remove the trim plate and then the end cover. Remove the rubber grommet and then the three cables from the clips. Replace with new cord.
Hobart Kitchenaid parts for mixer model K45
The WACEM (We Actually Collect Electric Mixers) web site has a downloadable PDF of the "K5-A, K45 Original Service Manual" in the "files" section.
This can help you figure out what has gone wrong with yours.
How do you tilt the head back on this k45 model?
You will find a sliding lever on the side opposite the speed control. Pushing it toward the rear will unlock the head and allow it to be lifted.
If this does not work, you will need the Service Manual which shows the locking mechanism's action:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
2answers
What model kitchenaid was made in december of 1973?
Is the brushed band around the head missing or worn off? The model is on that band. If it worn or missing in order to correctly answer your question I need more information. Is your mixer a tilt head or a bowl lift variety? Did you look on the bottom of the base for a serial number? Some models had them there. Can you describe the ceramic piece a little better? Many models shard the same internal parts and it might not be too difficult to locate that part.
Speed control on a K45 kitchenaid mixer only works on high speed.
Hiya,
I am sorry to hear you are having trouble with your speed on your mixer.
I have added a link below for a help video on adjusting your speed on your mixer:
https://www.youtube.com/watch?v=bM3t46afGcc
I hope this helps you!!
3helpful
Can a K4-b model be fitted with a K45 bowl?
No, it can not. I have the same k4b mixer and ive been researching the very same question as the k4b bowl is hard to find. The problem is that the k4b uses a small threaded mount stub centered at the bottom of the bowl and the newer design uses a much larger recessed well which is threaded to accept the threads on the bottom of the K45 bowl. Im thinking I might cut the base of the k4b and fit the bowl mount hardware pt no. w10191926 and use the paddle, whisk and dough hook designed for the K45 bowls shape.
Where can i find a hobart k45 replacement cord
You can purchase a replacement power cord from Amazon.com. It is part number 9701025 and includes the grounding style plug which the original did not have. It can also be purchased from your local Sears parts store but it will be much more expensive
1helpful
3answers
Which is the better mixer of these old models: K5A K5-A or K45 SS and what is the difference? KITCHENAID HOBART K5A K5-A 300 WATT MIXER and the KitchenAid Hobart Vintage K45 250 WATT. Thank you
Hello ajlina,
All of these are great home use units, all the attachments are interchangeable between these. The difference between these mixers is the K5 is a 5 quart mixer and the K45 is a 4.5 quart mixer. As I own both of them they are great in the kitchen and have the same durability.
Have any more questions please post to this thread and I will be happy to assist. Thank you for using FixYa.
1helpful
4answers
What kind of grease can be used on a stand mixer after replacing a stripped worm gear? model:K45SS
Food grade grease is what Kitchen Aid put into the gearbox originally. They do supply it as a spare part if you cannot find it as a non Kitchen Aid part.
1helpful
2answers
I took a KitchenAid K45 apart to clean (made in
What everyone is forgetting or they just don't know is that...The K45 introduced by Hobart in 1962 and was replaced in 1978 by the K45SS are two completely different machines. With completely different wiring systems. The K45 is wired together with wire nuts and the K45SS used connectors on the Speed control switch. All of the websites posted above are for the K45SS (Stands for Solid State) The manual for he K45SS is easy to get from Kitchenaid as the mixer electronics did not change from it's introduction in 1978 to 1986 when Hobart sold the Kitchenaid division to Whirlpool. The K45 on the other hand is a product and property of Hobart NOT Whirlpool or the Kitchenaid division of Whirlpool. The K45 Manual ... well I just can't find one! They way wires are routed is totally different in the K45 from the K45SS so the diagram in the K45SS manual does not help. Also the brushes in the K45 were square not camphor-ed like they are in the K45SS so there is no right or wrong way to insert the brushes in a K45. Whereas; in the K45SS there are four ways to insert the brushes in their holder and three of them are wrong. The K45SS brushes go into a completely different brush holder than the K45. The K45SS is the same today in 2012 as it was in 1978. The K45 is the same only from 1962 when Hobart introduced it to 1978 when it was replaced with the new Solid State model. prior to 1962 it was the K4-A model and it was different entirely. So if the people asking for help say their mixer is a K45 we should be asking for clarification as to a K45 or a K45SS.
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
