Sony Playstation 3 (PS3) Console Logo
Question about Sony Playstation 3 (PS3) Console
Hard disc corrupted on my p3
My P3 keeps on saying hard disc drive is corrupted and goes to restore but after the restore is done it goes back to the same saying hard disc drive is corrupted?
Posted by etha125 on
Anonymous
  • 1,472 Answers
Etha125
If you are getting the corrupted drive message this means that you have corrupted data on the hard drive or there is something wrong with the drive its self. The link below will help you address the corrupted data.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Aug 13, 2010
Notebook not working
Sounds like either the data is corrupt or the hard drive is bad. Try restoring the laptop back to factory defaults if you have the discs for it.
If you can't restore it after using the discs or just by installing windows, then that means the hard drive is bad and the hard drive would need to be replaced.
Hard disks file is corrupted
Has it asked you to reformat the hard disc? If you have tried that and it still doesn't work then you may need a new hard drive. Don't worry, for $20-$50 (US) you should be able to fix it. Without knowing what happened before that it's hard to say. But my best guess is that the hard drive is internally damaged in some way. Just take off the small panel on the left side, remove the screw, use the little handle and gently pull to the right then out. It should be a Seagate SATA hard drive 20, 40, 60, or 80GB. Just buy a new one from your local store or online. Make sure that you mark the bad one before you get the new one near it so you don't get tem mixed up. Then remove the 4 little screws on the mountinng cage, switch hard drives, install back into PS3 and it will give you the format screen again. Click yes and it will format, turn off, back on, and you should be all set!!
Hard disc corrupt
johnharnetty
If the PS3's built in repair will not fix the issue then you will need to pull the hard drive and format it on a computer. The link below will take you through the process. Note if you still have trouble then there is something wrong with the hard drive and you will need to replace it.
Issken
Playstation 3 message "hard disc file system is corrupted..."
Your hard drive may have gone bad. Maybe try using a different hard drive. Once you put it in, the system data should install itself.
Everytime time i set my ps3 up it says your hard disk has corrupted restore after restore has done it tries to restart then just says one agaian your hard drive has corrupted and keep going through the...
leep_hill
If you are getting the corrupted hard drive message this means that you have corrupted data on your hard drive. The link below will help you address this.
Issken
2helpful
Keep getting amessage saying hard disc corrupted.
Sounds like your hard drive is so badly faulty that it cannot be restored, in all likelihood you will need a replacement drive.
Can't use install discs
why dont u using booting CD? it much more easier..
1helpful
2answers
Swapped hard drive into new casw and now it wont boot up
This is due to a hardware conflict.
The system drivers on the hard drive are for the old mother board and devices,You will have to reinstall OS while it is install on the new mother board,The computer cannot boot to a drive that is loaded to another system unless all the devices and drive are identical.
Please rate this a fixya
Ps3 says the hard files have corrupted and will be restored ....
jvbeaudette
Issken
3answers
Upgrading hard disk
yes of course it will handle a 40gb hard drive..your P3 will handle a hard disk up to 60gb...coz i have a friend, his using a P3-700MHz,512mb, 64mb video card and barracuda 80gb hard disk=.)..to make it sure..bring your P3 to the computer shop so you can also know if your P3 is handle a 40-60gb hard drive..thanks..
Top Sony Video Game Consoles & Games Experts
Marvin
Marvin
Muzahura Frank
George Etukudo
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
