I put page 1 on my page 4 and I did it, but there is no number on rest of my document; pages 2,3,3... are blank
Posted by ladycdlc on
Anonymous
    Genius:
  • 1,027 Answers
I'll assume you mean MS Word and not an computer motherboard.
Page numbers are done by Insert command, Then Page Numbes. Specify the page location (left, Center, Right) in the pop-up window and you are done.Each page will then have the number at the bottom automatically.
Posted on Feb 14, 2010
Prints blank page
Have you checked the print que
Printer problems can be a real hassle.
From time to time, due to document layout or settings on your computer, in your software of choice, or even on your printer, a blank page may get "printed" with the rest of your document.
Fortunately, this issue is a simple one to troubleshoot.
Click "Print Preview" when you are finished with your document and ready to print.
Observe your document.
If you see an extra, blank page, you have created a second page.
To delete the second page, close Print Preview, go back into the document and eliminate any blank lines in your documents that you may not need.
You may also find an inadvertent page break at the end of your document.
Place your cursor on its symbol and delete it.
Locate the symbol by clicking on the Show Formatting paragraph icon in the toolbar.
Circumvent this "ghost page" if you do not see a second (or additional) blank page in Print Preview.
Specify the number of pages you wish to print, within the Print dialogue box.
This is typically done by selecting the "Print From" option, then entering the page numbers desired.
If your document happens to be ten pages (without, of course, that final blank page), then enter in the "Print From" field the numbers "1-10".
This will print only pages 1 through 10, without an eleventh (blank) page.
Jul 11, 2013 | HP Deskjet 5940 Photo InkJet Printer
My printer and jump over pages
I do not understand your problem. Can you provide a better failure description, please?
1) Do you mean that your printer was printing say page 5 of a 15 page document and suddenly jumper to page 14 and you are missing 9 pages of the document.
2) Your document is printing page 5 and suddenly you get 5 blank pages and then the text begins printing on page 6. No data is lost but you have 5 blank pages.
Problem 1: More than likely caused by a data flow control failure.
Problem 2: Can be a myrid of things. For example, Extral Line Feed commands accidently imbedded into the datatream, worn indexing parts allowing the motor to drive the paper up more then it is supposed.
Dec 10, 2009 | Epson Office Equipment & Supplies
In Word 2007, I have a document where the first two pages are un-numbered, the next page is numbered "ii", and the balance of the document is numbered 1 - whatever. The Office Online help is useless!
Forest,
The first two pages may be currently defined as a "Section" and is treated differently.
How do you want the numbering, or do you not want numbering?
Generally, Page one is NOT numbered and the rest are numbered, starting with "2", "3", etc.
Anyway, here is how to fix it:
Go to the top of the document and click your mouse in the upper left corner of the page (to make sure you are on the first page)
[Insert]
[Page Numbers]
Position: "Bottom of Page"
Alignment: Right
Uncheck [ ] Show number on first page
[Format]
Number format: "1,2,3,..."
[OK]
Oct 27, 2009 | Microsoft Office Professional 2007 Full...
The printer is feeding a blank sheet of paper between printed sheets. How do I rectify this?
This causes the printable area on the page to be that much less (10 3/4 or 10 1/2 on an 11 inch page). The software thinks the paper is 11 inches long and keeps track, down to the micro inch, where it is on the paper. When it reaches the 10 1/2 inches, your printer calls the page done and ejects it. However, the software thinks there is still another 1/2 inch to print (usually the footer area). Now when you insert a new sheet of paper, the software finishes printing the rest of the page (normally a blank footer) and form feeds to the next sheet. To correct what the software thinks the paper size is, you need to run the Preferences application and change the default settings. Select the Printer button. In the next window, select the 'Change Defaults....' button. Change both the Document size and the Paper size to a height of 10.875 and click OK. Try a new document to see if the paper size is correct. You may need to go back and change the height a few times until it is correct (the height changes in .125 increments). Usually either 10.875 (for 1/4 inch forced top margin printers) or 10.75 ( for 1/2 inch forced top margin printers) will work.
Oct 13, 2009 | HP Photosmart C6180 All-In-One InkJet...
MFC-6490CW, photocopy of 11x17 document prints 8 1/2 x 11 full scale image on 11x17 sheet. The image is centered on the 8 1/2 dimension, and located at one end of the 17 dimension. The rest of the 11x17...
First make sure you are not using "fit to page" as this feature does not work for legal size documents. To fix this problem we need to check several things. First, Press Copy, Load your document, press 1 for number of copies, press the up/down arrow until you get to "paper size" then choose legal (for 11x17). Press OK
It is also possible that your machine is set to reduce/enlarge size to less/more than 100%. If the first solution did not work start over, press copy, load document, enter 1 for number of copies, press up/down arrow to choose "enlarge/reduce" then use right/left arrows to choose 100% (again, do not choose 'fit to page') press OK. Once you have done this, you can set these as default if you like. Press Copy, press up/down arrow to choose new setting, press OK, press 1 to choose YES, press stop/exit.
Apr 18, 2009 | Brother Office Equipment & Supplies
Printing only upper part of page - big graphic PDF
1: check in the printer properties( page setup ) is it latter then make it A4
2: clean the roller
3: also when u printting check with uper try not from try 2
if its printing proper then try is touching roller
Mar 25, 2009 | Canon PIXMA MP540 All-In-One InkJet...
Prints extra blank page for every one page of printed material
hi,
try this
> unplug the usb cable from the computer
> click on "start--> control panel--> printers and faxes"
> select the printer icon associated with your printer and delete it.
> now plug the usb cable to the printer
> wait for few minutes while all the drivers are installed.
thats it... now try to print... it should be resolved
thanks and regards
agnel
Mar 17, 2008 | HP Photosmart 2710 All-In-One InkJet...
Computers & Internet Logo
32 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
