Question about HP Pavilion M9040N Elite Desktop PC
My cpu is slow, recently, my CPU fan is louder, every once and a while (often after using Firefox, but also other programs) the CPU fan speeds up to VERY high and loud levels....lasts 1min then returns normal..
  • Anonymous May 11, 2010
    Is your Cpu so slow or computer? Is there a process that is slow or it is the sound which annoys you. Try to use a compressed air cleaning the dust?
  • 667 Answers
Your computer is getting very hot it sounds like you may need a fan running near.
Posted on Feb 13, 2010
6ya staff
SOURCE:
Why will my fan not run during use but i hear it when the computer powers up?
Fans, mainly the CPU fan, have a speed control which slows the fan down. This is usually controlled by the BIOS. The speed is based on temperature of the CPU. If it's cool with little load the CPU fan will run very slowly and you won't be able to hear it. On startup all fans ramp up to 100% until the BIOS takes over and slows the fan down.
Jul 27, 2014 | Dell Inspiron 531s Desktop Computer
How to compaq 6400 bios slow
- Stop Overclocking your CPU.
- Make sure your Heat Sink is placed properly above the processor.
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Use CPU Heat Sink Paste in the processor.
- Fix OS registry with reliable program like I always use Reginout.
Hope these tips will help.
Feb 06, 2014 | HP Compaq nc6400 Notebook
Fan runs hard computer is slow hp compaq nc6000
- Shut down your computer at least two hour a day.
Jan 05, 2014 | HP Compaq 6735s Notebook
Asus K53SD HARDDRIVE SLOW
- Shut down your computer atleast two hour a day.
Dec 01, 2013 | ASUS Computers & Internet
Fan slow down and them high speed
change the fan ASAP, since the zooming noise and the slow performance will affect even the processor and you might end up replacing the processor as well if it persists. So get the fan ASAP and problem will be solved.
Sep 30, 2013 | Gateway GT5622 PC Desktop
What makes 511-cpu fan not detected and 512-chassis not detected
Are you seeing this error on a system you built or a pre-built system? If it is a pre-built system, check that the fans are running. Next check where the fans are plugged in, the CPU fan must be connected to the CPU fan connector on your motherboard. The chassis (rear case fan) only needs to be connected to the motherboard if you want the monitoring/PWM (modulated fan speed) option. If your CPU fan is powered directly from the power supply, change this.
If this is a system you built or recently updated the case, check your fan power connections, as above. Next check the fan speed. My ASUS board will give the "CPU fan not detected" error if the CPU fan speed is too slow. A different CPU fan will solve the problem. (I got my fan with the CPU; it works fine.)
I hope this helps. Please add a comment with more information about your system for more assistance.
May 12, 2013 | Computers & Internet
PC boots up very slowly and fan is very loud. Once up, it powers off after about 15 mins or so of use. Replaced power supplt last year.
If this is a name brand system like DELL it probably needs to have the CPU heatsink cleaned, and put new thermal grease between the heatsink and CPU.
It's slow because it's speed stepping the CPU to a lower speed because of overheating.
The heatsink grease is almost always the issue here.
May 27, 2011 | Computers & Internet
Variable speed fans suddenly slow single speed only.
check with the temperature of the CPU core!
because of over heating the CPU is shutting down or not.
Sep 24, 2009 | IBM Computers & Internet
Compaq Presario 3000 incredibly slow firing up, opening up anything. Loud fan all the time too
This advice relates to the Compaq Presario 3000 Notebook series but may also apply to other notebook computers as well.
The heat sink and fan assembly is probably clogged with dust and airborne particles. The clogged cooling parts can lead to heat problems with the CPU. When the system (CPU) gets to hot, the fan has to kick into high gear to try to cool things down. Once you remove dust and debre from the heat sink fins and fan, you will immediately experience better cooling and less fan usage. Your system may also be set for dynamic switching of CPU speed. If you CPU gets too hot, the system will reduce clock speed and ramp up fan and everything will slow way down. Use a good system monitoring software such as Notebook Hardware Control to monitor your CPU temperature, HDD temp and so forth. When the system starts getting too hot, first look at clogged heat sink fins as possible culprit. If you're good at electronics you may be able to service the unit yourself. Get a copy of the system's Maintenance and Service Manual or have a professional do the job for you as you will have to partially disassemble the computer to clean out the heat sink. Depending on the system, the job can take as little as 15-20 minutes once you become proficient at it.
May 09, 2009 | HP Laptop Keyboard for HP Compaq Presario...
My Sager laptop is running a program called VirtualDJ. This program runs videos. The computer's CPU is heating up to 95C in an hour and shutting down. How can I stop this. I had put a fan blowing air...
no there is no problum with your software . i think this is problum with your cpu fan. it is jaam or it is very slow. ple chack fan of Cpu is moving its normal speed.
if u can open ur laptop ple lubricate ur cpu fan
Jun 03, 2008 | Computers & Internet
HP Pavilion M9040N Elite Desktop PC Logo
336 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
