Televison & Video Logo
Posted on Feb 13, 2010
Bush LY1911WCW unlocking code - to make multi region - I have checked lots of sites and none have this TV/DVD combo listed
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
509
Points
Please can you help me of BUSH LY1911WCW region code and been try to dvd works but been watch the dvd had just half way and stop and why???
How to unlock DVD region on Tesco Technika 40F22B-FHD/DVD tv ?
To unlock DVD region on Tesco Technika 40F22B-FHD/DVD tv, you need to press Source or AV on the remote control and scroll to DVD, then press OK. Then you can make sure you have not loaded a DVD/CD, and then set the TV source to DVD. You may also need to adjust the Region settings in the DVD menu.
DVD region hack available?
If you suffer from region code troubles, you can download a region free DVD player software tool on your pc and then you can play discs of any regions you want. You can try Leawo Blu-ray Player which is a free Blu-ray player and a region free player.
Multi region code for bush cdvd3601hdmi dvd player?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Region code hack procedure to many popular devices are given.
2answers
BUSH 3081: What code will region free this DVD player? I bought this item listed as unlocked for all regions, but it says wrong region..
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure to many popular brand TVs and DVDs are given.
Is there a Unlock code for bush btvd91216w
This is everything that I have:
Try this general bush unlock:
Press Open tray
Press 2, 8, 1, 2 and Enter to get to the manufacturers settings
Select the required region, by pressing Enter on 9 for multi region
Press Close tray
If that didn't work, try this:
Try this one:
1. Press the Open button on your remote control to open the drive tray
2. Press the 9 button on your remote control
3. Press the 7 button on your remote control
4. Press the 3 button on your remote control
5. Press the 5 button on your remote control
6. Using the on screen menu, highlight the region option
7. Press the Right button on your remote control
8. Using your remote control, select 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
9. Press the Enter button on your remote control
10. Press the Open button on your remote control to close the drive tray
Then there is the following and good luck:
Bush 1000
  1. Open the tray
  2. Insert a disc with desired region code, but do not close the disc tray
  3. Press 0, 1, 2, 3, Play
Bush 1005 / 2004A / DVDAV7
  1. Press the OPEN/CLOSE on the remote
  2. Press 3, 3, 0, 8, 8
  3. Press the button for the desired region or 0 for multi-region
  4. Press OPEN/CLOSE
  5. The on-screen display will now indicate the currently selected region
Bush 2000
  1. Open the disc tray
  2. Insert RC-1 DVD, don't close the disc tray
  3. Press 0, 1, 2, 3
  4. Press PLAY
    To activate RC 2:
  2. Insert RC-2 DVD, don't close the disc tray
  3. Press RETURN and PLAY
Bush 2002 / 2004
  1. Press OPEN
  2. Press 7, ENTER, 7
    A menu should appear (codefree=13)
    Method 2:
  1. Press OPEN
  2. Press 2, 0, 0, 1
Bush 2005 / 2008 / 2009
  1. Turn on the player
  2. Press OPEN/CLOSE
  3. Press ZOOM
  4. Press A/B
  5. Press Up, Left, Down, Right
    A note should be displayed.
  6. Turn it off
  7. Turn it on
Bush 2023 / 2024 / 2523
  1. Press OPEN
  2. Press 2, 8, 1, 2, Enter
  3. Set the country code to 13 and press Close
Bush 2028
    already region free
Bush 2039
  1. Press OPEN
  2. Press PROG
  3. Press ENTER three times
  4. Use UP/DOWN to select region
  5. Press STOP several times to set the region
Bush 2047
  1. Press OPEN, SETUP
  2. Go to "Preferences"
  3. Enter 2, 8, 1, 2
  4. Use UP/DOWN keys to select the region
  5. Press SETUP, OPEN
Bush DVD-102
  1. Press OPEN/CLOSE
  2. Press 2, 0, 0, 1
  3. Press ENTER
  4. Select RC (codefree=13). You can disable MacroVision, too.
  5. Press OPEN/CLOSE
Bush DVD-142TV
  1. Press DVD function on your TV set
  2. Press DVD Setup on the remote
  3. Press 1, 3, 6, 9
  4. Press Left three times
  5. Press RIGHT once
  6. Select VERSION
  7. Change the region code
Bush DVD-143TV
  1. Press DVD/TV, DVD
  2. Open the tray
  3. Press SETUP, Right, Left, Down, Up, Display
  4. Enter 0 (or 1-6 for other RC)
  5. Press Enter
    VCD/SVCD playback
  1. Press SETUP on remote
  2. Press Next, Prev, Next, Prev
    Ver should appear in the top right
  3. Change 3001 to 3000
  4. Change 5001 to 5000
Bush DVDAV11K
  1. Open the tray (be sure to be in stop mode)
  2. Press SETUP, Next, Prev, Next, Prev
  3. Select 255 for region free (use LEFT/RIGHT)
  4. Press SETUP
Bush DVDR3000
  1. The disc tray has to be empty
  2. Press TV/DVDR
  3. Press RETURN, DISPLAY
  4. Enter 8, 8, 8, 0
Bush DVHS1
  1. Press the DVD button on the remote
  2. Press OPEN
  3. Press 0, 5, 2, 0
  4. Press UP, DOWN, LEFT, RIGHT
  5. Change the region (0 = multi-region)
Bush DVRHS02
  1. Push SETUP button on the remote
  2. Select SYSTEM INFO on the menu
  3. Enter 1, 1, 0, 1
  4. It shows the current region code
  5. Push 0 on the remote for region free
Bush 2001 / 2020 / 2026 / 2029 / 2035XI / 2038 / 2042 / 5020 / BTV213DVD / DVR3000 / DVRS01 / PDVD0707 no known hacks
1helpful
Multi-region DVD
verify in the setup menu of your dvd ie put no disc in and go to setup check to see if there is a region setting in there and that it has not been switched
How can i unlock my samsung home cinema to multi region dvd so that it can play any dvd,vcd e.t.c
dvd region free codes site
http://www.dvdhacks.co.uk/
check out the link bychance it helps you.as many region codes r listed in it.
1helpful
2answers
DVD UNLOCK CODE
I've checked and theres no remote input to make it multi region. It could be done with a Pocket pc with infared apparently but this seems tricky. I searched 6 different DVD code sites for a code but the pocket pc one is all it came up with. Its seems to be the same for most DMR versions. You could also use a pre-cracked remote to do it. Sorry i couldn't find anything for you.
BUSH DVD2038
hi i'm trying to change region so i can watch can you help
Top Bush Televison & Video Experts
matt martin
matt martin
Sean Wright
Sean Wright
john h
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
