SanDisk Sansa Shaker SDMX9N-512 MP3 Player Logo
Posted on Feb 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I HAVE SYNCHED THE MUSIC BUT ONLY THE SONGS THAT WERE ALREADEY ON WILL PLAY
Anonymous
Level 3:
  • Master 593 Answers
  • Posted on Feb 14, 2010
Anonymous
Master
Level 3:
Answers
593
Questions
0
Helped
175306
Points
1850
Just to be clear,most players require no special drivers. MSC mode will work out of the box with just about any MP3 player and any OS (W*ndows Linux). MTP mode will work as long as you have WMP 10 or 11 installed. Firstly, I will try to explain MSC mode and MTP mode and what they mean. MSC stands for Mass Storage Class. When your player is in this mode, the computer will see it the same way it would see a Thumb drive or flash drive, as a removable disk. It will assign the first available drive letter to your device, as well as one for the memory card (if it uses one and it is installed). This is probably the more popular of the 2 modes, and is a more "open source" type of standard. Most computers detect the player in this mode without a problem very well and right away.
MTP stands for Media Transfer Protocol. It is a Microsoft standard and is Microsoft's solution to connecting MP3 players and cameras to a w*ndow based Computer. MTP mode must be used in order to transfer ANY Digital Rights Management (DRM) protected content. MP3's downloaded form services like Rhapsody and Napster will only function in this MTP mode.
Most good MP3 players will have both of these modes at the users options.
Although not all do, so it is a good idea to check yours for these settings if you are having connection problems
NOTE: Any songs added to your player in MSC mode will not be available in MTP mode and vise-a-versa. In other words You can't see the files added in the other mode and you can not play them. You know you have some files on your player and can not find them now, you may have to change modes so they are available. Some players in the SanDisk line up use Instead, an "Auto Detect" function that is suppose to Automaticly use MTP mode. If MTP mode does not work for any reason, it should default to MSC mode.
To use MSC or MTP modes go to your players settings.
These settings will vary based on player model and you might have to refer to your users Manual. Check their web site for a download in PDF form. Turn the player on, if it is not already Navigate to the main menu of your player; this is the same menu that gives us options such as Play, Record, Info, etc... Navigate to "Settings" on the main menu of the player. After navigating to "Settings", you should see an option that states "USB" or "USB MODE" From here we can select MSC or MTP modes (could vary based on player model) Highlight the desired mode and select it, at this point it will roll back to the 'Settings' menu Connect the player to your computer and verify it is connecting in the desired mode. It should be noted, when a device is in MSC mode, it will appear as a "Removable disk". When connected in MTP mode, it will show up as an "Audio Device".
Now most players now days can and will use`MS W*ndows Media Player. You can also try to reinstall W*ndows Media Player 10 or 11 Next W*ndows has a update to fix if all else fails try this link. http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en
Sony Walkman MP3 doesn't respond to buttons -- won't even turn off
Sorry to hear that. Just press the RESET button to see if it solves the problem. If not, go to the Sony Support Center online.
Good luck, and Happy Holidays.
MA 715 Will not play all the songs written to it
u have to drag da music to the music files straight to da mp3 player u cant sync them because they will go strait to folders and u cant listin,,,,, if they are now in folders on ur mp3 go onto it from ur mp3 and take the nice long time of taking them out of the folders
2answers
Music on iPod stops randomly and skips to next song
i dont know for sure what the problem is but is it possibile that you have a virus on your computer? i was thinking you may of cought a virus on your ipod. but this is just a guess.
Sansa m230 won't play my PC's music
Not sure what fixed it. I formatted the player - which, of course, deleted all that was on it. I refreshed the player. and just fiddled around with it. Now the music plays and I also downloaded a couple of books onto it. Also read someof the other questions and solutions you had on your web site. Thanks for your help.
My mp3 player wont play anything
hmmm, that means that you may have synched some songs that are not fully compatible with your go-gear. although it is still mp3, it may have some "codecs" issues with it. and thus making your go gear crazy. what you can do is delete all the songs you have there, and make a fresh start from scratch, that way, you'll know.
2answers
Mp3 player
After I have synched the songs into the MP3 I go into my computer open up the mp3 take the songs out of the folders in the mp3 and put them back into the mp3 without the folders
2answers
turn every program but itunes off. your firewall is interrupting your sync. close all programs or turn off your anti-virus and firewall so nothing can interrupt. keep me posted with results.
I synched my songs to my player, yet they won't play
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Message on SanDisk e260 MP player
Upgrade your subscription - the lower-level subs do not hve transfer rights
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
