Question about XM Radio (XMP6000)
I use my xm radio through the fm channels on my car stereo. The menu has the fm channels where I can program which station I want to set the xm radio on. Sometimes when I start the car the xm radio resets and the fm channels option doesn't show up on the menu screen anymore. I usually have to unplug everything and wait a few minutes before it will start working again. Is there something I can do to keep this from happening or is this a defect in my radio?
Posted by rkwaldeck on
5 Related Answers
Anonymous
SOURCE: xm stopped working display says "antenna"
Broken antenna cable. Likely you have a kink or worn thru point on the wire somewhere.
Posted on Sep 17, 2008
Anonymous
SOURCE: XM Loading Problem for Volkswagen
I had the same issue. I called XM multiple time to have the signal resent. I told them I was receiving the preview channels and nothing else. I asked them multiple times if it could be hardware issue and they said no. I took it to the dealer and they ran a test ($98) and determined that the unit had failed. They didn't charge me for the $800 unit, but they did charge me $300 for the installation. Its working fine now.
Posted on Apr 13, 2009
Anonymous
  • 578 Answers
SOURCE: I have an '08 Hyundai Santa Fe. My XM subscription
un plug the xm antenna and plug the radio antenna in by it self you should get radio signal
Posted on Jun 26, 2009
Anonymous
  • 20 Answers
SOURCE: I have XM radio in my chevy malibu. Worked fine
I believe when the antenna loses power it does not show it on the screen sounds like there might be a break in the antenna wire or simply came out of socket in the rear of the radio.
Posted on Nov 03, 2009
Anonymous
SOURCE: My xm radio stopped working in a 2009 silverado.
Having the same problem in my 2009 Malibu. Have received 8 refresh signals and talked to the XM Techs 4 times. Taking car to dealership on Monday. Highly frustrated.
Posted on Apr 22, 2010
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
FM Transmitter does not connect to car radio, have FX signal and Line out works.
Car cradle works "wirelessly" with Car Radio (inherent design of unit). Place Unit in Cradle; connect Cradle to Auto Power Source, and SkyFi3 should power on. Press Menu to Get FM Radio station channels; select a lower station Channel Frequency i.e. 88.3 or any vacant channel number and the signal should transfer to your Radio speakers automatically. You can change Station frequencies as often as you need to do so--for example if traveling through different broadcast areas, some channels frequencies are clearer than others. Good luck.
Jul 19, 2010 | Delphi SKYFi3 XM Radio Receiver
Delphi skyfi2 Xm Radio Receiver car connection
Yes, you can buy an FM Direct adapter that will allow you to transmit directly to your car FM tuner, but if you have an older SkyFi2, the Fm transmitter is so strong, you can sit the radio on the floor and tune your car radio to your preset XM channel, like 107.1 FM and it will work great. Go into "Menu" and pick a channel that's not used locally.
Jul 12, 2010 | Delphi SKYFi2 SA10101 XM Radio Receiver
What or how do I install my Skyfi2 in my car without a tape deck?
Do you have a newer one (red and yellow box) or an older one (bubble box or white box?). If it says 'direct connect' in a reddish box it has a really cruddy FM modulator, if it is an older model from the clear plastic bubble box or white box, it has a really, really strong FM transmitter in it (so strong, the FCC outlawed it) and you can use it to transmit to an empty FM channel (within 50 feet of your radio!) So my answer is, simply go to the 'MENU" and under "FM Frequency" select an empty channel in your area, like 107.3MHZ and then set your car radio to 107.3 FM and it will come thru. You can also adjust the "Audio Level" in the MENU to make it even louder. Should work real well, Just check at the very ends of the FM band for channels first and try to set it 2 channels away from an active channel, so if you have a station on 106.5, you want to be on 106.9 or higher, etc.. Okay?
Jun 14, 2010 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
How do I get to radio tune
Turn XM Roady2 'on' using the POWER switch. Go to MENU and go the FM Frequency. Select your frequency of an empty channel in your area, then turn off the Roady2 using the POWER switch. Do NOT do this by turning the car on and off as it tends not to save any settings when you do that. Always use the POWER button. Also, the website 'Radio-Locator' has a utility that will help you find an EMPTY FM channel in your are for your XM radio to use! Good luck and let me know how it works out for you- okay?
Jun 12, 2010 | Delphi Roady2 SA10085 XM Radio Receiver...
Roady XT XM Radio Receiver: how do I change the radio station i want my xm to ...
First of all find a clear fm stn. on your car radio.Go to xm radio and push menu until fm freq. shows up.Push sel and use up or down arrows until the freq. matches that on car radio. push select again to set it.
May 07, 2010 | Delphi Roady XT XM Radio Receiver
How to set FM Frequency on XM Radio Delpi SkyFi
is this a skyfi 1 2 or 3. if its a two or three if you go to the menu button and scroll down to fm frequencys and select that from the drop down menu. then scroll through the built in frequencies and determine which one comes in the clearest. if its a skyfi one then your gonna have to put in a wired fm modulator because the first one doesnt come with a wireless fm transmitter.
Jan 22, 2009 | Car Audio & Video
Wireless FM modulator
first you have to set a channel in your sat radio then tune your car radio to that channel go to menu and then to set fm frequency in your sat radio and choose one try to get one that does not have a station on it whatever you set it at just tune your car radio to that frequency and it will work
Dec 05, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
MyFi FM Modulator Stopped Working?
hi there..there are few ways on installing xm into your car..you can use the FM Modulation that you're doing before..it goes like this...make sure that you're xm radio is turn off( with all the wirings unplug).....then, you just have to go on a blank channel(e.g 90.1) on your car radio...afterwhich, turn on your xm radio and go to MENU....and look for FM settings...and select the same frequency you have into your car radio...and just have to wait for 5 to 8 secs and you should be getting the prev. channels.....
IF: you're only getting prev. channels such as 1, 130 etc...you just have to call xm to send a refresh signal OR you can go to www.refresh.xmradio.com if you want to save more time...just type in your 8 digit radio I.D....
IF:
you're not getting the FM settings.....you just have to click the MENU and select the 'default settings/factory settings' then turn off/on your radio to save the changes...
i'm sure it'll work nowq at this time....Godbless!
Aug 23, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Car Audio & Video Logo
Top XM Radio Car Audio & Video Experts
xxxxxx xxx
 Mikey
Mikey
Are you a XM Radio Car Audio and Video Expert? Answer questions, earn points and help others
