How do you hook it up to a pioneer amplifier VSX-D711 which has one philips coacil for sub-woofer. Do I connect to Left/LFE in lower right corner section (Line In)? kym2009
I don't recall correctly if your Pioneer has a sub out RCA connector, and if the Kenwood SW-07 has a low level input. So the usual way is to connect it using the speaker wires.
You connect either the FL or the FR to the sub and it should work.
Yes, go to your menu then setup then speakers then subwoofer, it's probably in "LFE" it should give you the option of Sub, LFE, or Both. that should do the trick. Also check the crossover point and season to taste. While your at it; there should also be a setting for speaker level, toggle down to sub and adjust the sub out level, it's probably at it's minimum setting. Hope this helps
Rear Surrounds are not supported on this unit, they would be the 6th and 7th channels in a 7.1 rig. I think you mean Surrounds (channels 4 and 5 in a 5.1 rig).
Lets ponder: How is there any relationship between Surrounds and your separately-amplified Subwoofer? I don't see it, unless you inadvertently chose OFF for the Sub definition when you were in the Speaker selection menus adding the Surrounds. Look again.
Your receiver should have an RCA connector on the back panel that will be marked "sub woofer" or "LFE out". That connects to your sub woofer with a standard RCA type cable. Also, some powered subs have left and right speaker level inputs and outputs in which you would indeed run the sub woofer through the speaker outputs. The down side of that type of connection is that the line level converter inside the sub woofer will take a slight amount of your receiver's output power, although that is rarely detectable. Also, if you have a Dolby Digital receiver, using this connection method will take away systems ability to accurately control the low frequency effects of a soundtrack.
Based upon your description, the subwoofer is just a speaker and is taken from the normal speaker outputs. Run your A channel to the sub and then from the sub to the left and right front speakers. That should do it.
Dan
You need to connect most turntables to a PHONO input or buy a PHONO preamp. Many newer receivers do not have a PHONO input.
The AUX port you are using would work fine for a device like a CD player, but turntables need to be amplified. You can buy an external Phono pre-amp from Radio Shack.
I don't know anything about this site, but something like this device should work for you.
http://www.phonopreamps.com/tc400pp.html
