Computers & Internet Logo
Anonymous Posted on Feb 13, 2010
VANTEC ION 2 520 W PSU!8)
HELLO!8) IS A Vantec ION 2 520W PSU ENOUGH FOR A SYSTEM LIKE BELOW?
AMD PHENOM II X3 710
COOLER MASTER HYPER 212 PLUS
HIS RADEON HD5770
KINGSTON VALUE RAM 800MHz 4GB RAM
COOLER MASTER SILENT 120MM HIGH PERFORMANCE FAN X6
ECS BLACK SERIES A780GM-A
I THINK CROSSFIRING WITH THIS PSU IS POSIBBLE BUT JUST TO MAKE SURE,CAN 2 5770'S WORK!
NOTE THAT THE SYSTEM ABOVE IS JUST AN UPGRADE LIST.
THNX FOR ANY HELP8)
Steve Nordquist
Level 3:
  • Master 982 Answers
  • Posted on Feb 13, 2010
Steve Nordquist
Master
Level 3:
Answers
982
Questions
Helped
213345
Points
2276
Yeah, that would hack it. I could see wanting a 700W-rated supply in case I sourced nicer (but higher-draw) videocards, but that's enough.
Testimonial: "THNX Saigua.+12V1 AND V2 RAIL THERE'S 20AMPS SO XFIRE IS POSSIBLE.OH BEFORE I FORGET I'M PUTING THIS PSU IN A TT V3 CASING WILL THERE BE ANY PROBLEMS."
Replacing power source
IF YOU MEAN PSU STUDY HOW THE YOU REPLACING IS
MOUNTED AND CABELS LAYD.
1helpful
Upgraded cpu and fan om HP p6320y desktop won't stay powered up
The AMD Phenom II X4 850 (HDX850WFK42GM) uses up to 95 Watts of power,
http://www.cpu-world.com/CPUs/K10/AMD-Phenom%20II%20X4%20850.html
(Electrical/Thermal parameters)
While the AMD Phenom II X4 965 uses up to 125 Watts, or 140 Watts; depending on which Part Number....
HDZ965FBK4DGI uses up to 140 Watts.
HDZ965FBK4DGM uses up to 125 Watts.
http://en.wikipedia.org/wiki/List_of_AMD_Phenom_microprocessors#.22Deneb.22_.28C2.2FC3.2C_45_nm.2C_Quad-core.29
Scroll down a little.
I'm going with Not enough power from the Power Supply.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01969880&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=4120661
Power Supply is ONLY 300 Watts?
Yes, the Power Supply is too small IMHO.
Is there also a graphics card you have installed, and not stated?
Regards,
joecoolvette
Phenom ii x4 965 m2n68-am plus
Yes it will because I have the se edition of it. However I cannot recommend this combination because if this is like the se version it only supports a max of 4 gigs of ram. Shockingly 4 gigs of ram is still enough to play almost all titles that I know of. With that said I think serious pc gamers want at least 8 gigs. I'd recommend 16 gigs now a days.
1helpful
CPU upgrade for ACER rs780hvf
you could upgrade to AMD PHENOM II X4 960T but you should probably try and overclock and save your money.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
1helpful
4answers
Id like to buy a msi nf725gtm-p31 mobo but am unsure if it supports am2 processors and ddr2 can u pls advice thanks
Here are the specs of the motherboard, both answers to your questions are "Yes". Happy purchase and have fun with it !
CPU
• Support socket AM2 for AMD® Athlon 64/Athlon 64X2 CPU / AM2+ for AMD® Phenom CPU / AM3 for AMD® Phenom II / Athlon II CPU . (95W only)
Please refer to CPU Support for compatible CPU; the above description is for reference only.
bult_ar_org.gifHyper Transport Bus
• HyperTransport 1.0 supporting speed up to 1000MT/s
bult_ar_org.gifChipset
NVIDIA® nForce 630a & GeForce 7025 chipset
bult_ar_org.gifMain Memory
• Supports Dual Channel DDR2 667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 8GB.
bult_ar_org.gifSlots
• One PCI Express 1.0 x16 slot.
• One PCI Express 1.0 x1 slot.
• Two PCI slots (support 3.3v/5v PCI bus interface).
bult_ar_org.gifOn-Board IDE
• One IDE port by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
bult_ar_org.gifOn-Board SATA
• Two SATA II ports by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports storage and data transfers at up to 3Gb/s
bult_ar_org.gifRAID Function
- SATA II 1~2 supports RAID 0, 1 mode by NVIDIA® nForce 630a & GeForce 7025 chipset
Hello....first question, is the Vantec IDE to SATA compatible with windows 7 64-bit? Thank you Ted
Win 7 should recognize the drives. However, whether your current hardware will recognize the drives is another question.
I've seen posts where it works in some situations, and not others. Amazon has 10 reviews with ratings running the gamut. Seems to be a "Hit or miss" proposition.
Amazon link:
http://www.amazon.com/Vantec-CB-IS100-SATA-Converter-Black/dp/B000Z3K47G/ref=cm_cr_pr_product_top
14helpful
2answers
Vantec Nexstar 3 driver download
Vantec Nexstar 3 drivers can be found at driverupdate us.Take a look, and enjoy
NEED HELP 8(. GAMING CASE
case sounds fine, a little iffy on the power supply.
2helpful
2answers
Not working after wrong settings
If your main power is 220Vac and it is set in 115Vac. It could be you actually fried your power supply.
Here is the reason, in common power supply after the rectifier diode when it is set in 115Vac, its circuit acts as a voltage doubler, its mean in its downsteams it actually uses around 220Vdc. And when you uses it in 220Vac it will connect directly as a rectifier.
When you set it in 115Vac and plug in 220Vac. In its downstream it could be in 440Vdc, then its an overvoltage everything that can't compensate will be damaged.
Hope I give you some info.
Can my Vantec NexStar 3 Hard drive SAVE?
You might want to take the drive out of the case and use and external drive connector to see if the drive still works.
https://www.amazon.com/Drive-Adapter-Converter-Optical-External/dp/B002OV1VJW
Grand Canyon Tech
Grand Canyon Tech
