Question about Canon PIXMA MP610 InkJet Printer
My mp610 has just got new inks in it. I did the calibration and everything was fine but when I printed off a PDF document it only printed the coloured text and not the black. could it be possible that the pg-5bk ink cartridge needs replacing also as I just replaced the cli8's.
Posted by garbo_man on
Melvictor Gopez
  • 62 Answers
Yes because u installed both cartridges. if you only installed the color it will still print black by mixing the three colors (known as composite black) try to change the black first or remove it and use the composite black to print black text.
Posted on Feb 13, 2010
Canon mp610 will not print black. It prints in color or dark grey but a black text document comes out blank
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
May 26, 2011 | Canon MP610 Photo All-In-One Printer
All my ink cartridges are full, yet anything that needs black ink that is sent from the computer doesn't work. It feeds through and prints everything else but black even with new full cartridges. It copies...
You might try changing preferences in control panel. The defualt for most photo printers is color since that is the most used feature (and sells the most expensive ink!). I finally bought an HP 1000 to use for everyday printing of documents and business items becuase it only needed black and white ink.
Mar 21, 2011 | Canon MP610 Photo All-In-One Printer
New pixma, new ink, properly installed, wont print!!!
On board Self test mode operate?
OH no are you scanning anything when you hit the start button?
If not it is an All in One printer scanner fax.
If the drivers are installed abnd the computer is pointing to it bring up a document by using the computer and send it to the printer
Jul 27, 2009 | Canon MP610 Photo All-In-One Printer
Black ink problem with printout on hp7780
Always try replacing the ink cartridges first.
It sounds like the print heads in the 7780 are bad. Don't confuse the ink cartridges with print heads. The cartridges fit inside the print heads. You will need to change the heads. Here is a link to HP's how-to.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00841890&tmp_track_link=ot_faqs/top_issues/en_us/c00841890/loc:1&lc=en&dlc=en&cc=us&lang=en&product=2512010
Could have the same problem with the Dell.
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Printin Problem
Call Kodak for a new printhead. The printheads go bad.
Dec 20, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
The black, print quality when printing a document on white paper, is not 100%
Few questions, are you running true Canon Inks and refills are always a off black not a true canon black!
Have you tried doing nozzel check, does the top black squares all come out ok? if so it could be down to the paper and the inks!
if you use 80gsm paper does it print ok?
Hope this helps
Sep 30, 2008 | Canon MP610 Photo All-In-One Printer
Problem with printed documents
your printer needs calibration. Read in the manual how to calibrate ink cartridges and it should fix the problem up. Cheers
Aug 03, 2008 | Canon PIXMA iP1600 Printer
Color prints too dark
1. Took out the color ink cart and clean the copper contacts of the ink cart with cotton swab, make sure that you do not touch the silver nozzle .
2. Try new ink color ink carts as someime this issue came up when the ink carts are about to finish up.
3. Replace the ink carts and do not us a refill ink.
Dec 26, 2007 | HP OfficeJet D135 All-In-One InkJet...
Canon PIXMA MP610 InkJet Printer Logo
276 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
