Question about Refrigerators
My whirlpool is leaking water under the vegetable/fruit bins and inside the cheese/meat bin.
Posted by SPELLYA on
Anonymous
  • 572 Answers
Defrost it, remove back panel on freezer side, and unclog small hole where water collects
Posted on Feb 13, 2010
Ice build up under vegetable and fruit bins
Pull the bins out. Just above them is a channel with a hole in the middle. Push a drinking straw in the hole to clear the drain. The water will drain away instead of dripping under the veg bins.
May 04, 2017 | Refrigerators
Where is the draining hole in a ge profile model tbx25pa refrigerator with top freezer
Underneath the cooling coil (evaporator) located in the freezer, there is a drain pan with a heater to warm it during the defrost cycle. The drain opening is probably blocked by ice or debris.
Sep 26, 2014 | GE Refrigerators
My whirlpool refrigerator Model ET18PKX6W00 leaks water under vegetable bins
Check behind the bins for a condensation tray/hose. Most refrigerators have these as they develop condensation due to the temperature differences when opening and closing the door. The tray catches the condensation, and drains it to a tray under the fridge. Here it evaporates when the compressor runs. Sometimes things block the tray or the hose gets clogged with gunk. clean out the tray/hose and hopefully your problem will end.
Dec 30, 2011 | Whirlpool Refrigerators
What is the best temperature to keep the refrigerator ( Hotpoint)
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:SIY_RFFRIDGETEMP
What should a Hotpoint fridge temperature be?
Your Hotpoint fridge is designed to operate at a temperature ranging from 0.5 degrees in the coldest part up to 5 degrees inthe warmest part.
As warm air rises and cold air falls it is safe to say that the best way to store your food is to place it in the most appropriate shelf compartment, as shown in the diagram below.
  • Zone A - Cool Dairy Products, Cheese, Butter, Margarine, Low Fat Spreads, Cooking Fats/Lards, Preserves, Jams, Curs, Marmalade, Salad Dressing or Sauces
  • Zone B - Colder General Food Storage
  • Zone C - Coldest Meat, fish & poultry, Pre-cooked/chilled food
  • Zone D - Salad Bin, Vegetables, Fruit and Salad Items
May 08, 2011 | Hotpoint Refrigerators
Vegetables in fruit and vegetable bin is freezing.
I solved my problem by going someplace that wasn't going to charge me!
Jan 07, 2010 | Amana AFD2535DES French Door Refrigerator
Water collects in bottom of refrigerator under fruit/vegetable bins
When a fridge goes in to defrost it melts the ice on the coils in the interior of the freezer. Often times there is a drain that runs to a sliding tray under the fridge. If this is clogged you will get water building up under the bins.
Jul 10, 2009 | Refrigerators
Water in bottom of frigerator
Hi, The drain is plugged coming from the freezer section. Please get me a model# and I can assist you with this problem. Thanks Vic
Jun 14, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water accumulating under the fruit and vegetable bins
If you look behind the panel inside the fresh food section there is a drain coming from freezer and then to outside back and down to a tray next to compressor. The drain is most likely blocked there. Let me know if I am wrong, Sea Breeze
May 18, 2009 | Refrigerators
Refrigerators Logo
213 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
