Question about Power Acoustik PTID8400 Car DVD Player
I've been having a problem with my power acoustik PTID-8001N unit. When I put a cd in it gives an error disc. What can i do to correct this problem?
Posted by jdguillory on
dj_relly999
    President:
  • 4,070 Answers
Hi, you may run a disc cleaner for the optic lens might be dirty, hope this helps
Posted on Feb 13, 2010
  • kordelljeffe Dec 05, 2010
    its brand new so i shouldnt have to do that yet
Jonathan Ellmann
    New Friend:
I have just bought the PTID-8920B and I can't play dvd/CD at all for some reason
Posted on Jan 10, 2015
What are the features?
POWER ACOUSTIK PTID-3265S CD/MP3/USB/DVD 3.2" TV STEREO SCREEN & 6.5" SPEAKERS
Mar 08, 2013 | Power Acoustik PTID-3265S
I have a Power Acoustik PTID-7000NR and the cd is stuck and will not come out. It plays fien and everything else works. But the CD will not come out. Any suggestions? Thanks!
you may have two cd`s inside take the radio out and take it apart. inside the radio there is a realese for the cd tray but you have to have power to the unit for it to work. eject the cd from the front then hit the release on the inside its a little tricky but you should be able to find it
Sep 20, 2011 | Power Acoustik PTID7000NR Car Video Player
How to hook up the ground wire the red wire and yellow wire
Usually, wiring schematics or color codes are universal. try these simple color codes:
Red - Positive line (+) - to battery or capacitor
Black - ground (-) - must be attached to the body of the vehicle
Yellow - Ignition switch line
Other white-lined wires paired with solid colored ones are usually for front and rear speakers.
There might also be 2 wires that is labeled "LINE OUT" which goes to the LINE IN of your Power Amplifier.
Dec 09, 2010 | Power Acoustik PTID-8001N Car DVD Player
I HAVE A POWER ACOUSTIK PTID-8970NRBT MY PROBLEM MY SCREENSAVER
Here is what I received from Power Acoustik for screensaver and desktop saving from SD card. "You need to have the remote in hand. Insert a memory stick or SD card that has the images you want to use. When the image is displayed, press the pause button on the remote. Then touch the screen to bring up a set of icons on the bottom. If you do not see an icon with a hand, press the arrows that are in a circle until you do. Once you see the hand, press it one time. It will save the image onto the internal memory. You will find the image in the screen tab in settings, under all the stock images."
Mar 17, 2010 | Power Acoustik PADVD340TV In-Dash...
How do i set my ipod to my power acoustik ptid 5300 when i plug it in it just says close
If you bought the correct cable it should work automatically. There are no settings. However, my 5300 was flakey right out of the box and I had to send it in for repair. It works perfectly now.
Jun 06, 2009 | Power Acoustik PTID-4003TV Car Video...
Power Acoustik PTID-4007 Okay, so I checked my radio fuse, it's fine. Checked for constant and acc 12v. and they are there. fuses on harness are good. I spliced my adapter harness onto the PTID-4007...
i have Power Acoustik PTID-4007 my problem is not turn on lcd not out audio but yes is take cd and out cd, the screen is move in three postion. help me please
thanks
Mar 08, 2009 | Power Acoustik PTID-4006T Car Video Player
My power acoustik 8960 touch screen does not respond
return it...it will start jamming when loading a disc and the fan will start to grind soon.  it is a bad unit..like all 3 I have HAD!!!!!
Feb 18, 2009 | Power Acoustik PTID-8960 Car Video Player
Ignore the above comment... SD cards and USB play fine on there (i have one).
Mine does the same, but leave it for 5-10 seconds after it says close and it loads it up!
Mar 29, 2008 | Power Acoustik PTID-4003TV Car Video...
Power Acoustik PTID8400 Car DVD Player Logo
583 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
