Question about DISH Network ViP622 DVR DTV Receiver / 180-Hours Video Recorder
If I don't have a cable or satellite television service how to install a VIP 622 DVR HD Antenna
Posted by john_dima on
Jim Franks
  • 374 Answers
Mount the dish on a pole or house using a mast perfectly plumb. Ensure it will give you an unobstructed view of the sky based on the information that should have come with the dish regarding your zip code for skew, elevation and azimuth settings. You will now need to run one line from the LNB on the end of the skew arm to your 622. Remember to use a seperater inside or you will need to run another line into the back of the receiver. Run a hardwire off back of the receiver's home distribution port to . Connect a line from 3-4 on back of the receiver to your TV 1. ....More to come if needed drop me another line.
Thanks for using Fix Ya.
Jim
Posted on Mar 01, 2010
Is this resiver HD ?
am_witek,
Our 625 receiver is not an HD model. Our current HD models are ViP 211/211k, 222, 612, 622, 722/722k, 922, and our Hopper receiver.
If you have any other questions, let me know!
Tommy Faust
DISH Social Media Representative
Nov 24, 2012 | DISH Network DVR-625 DTV Receiver /...
Can't record with dvd recorder from hd digital cable box
Hello, Ciprian -
Your television service provider (cable or satellite dish) provider may not allow DVRs which the company does not provide. We have AT&T Uverse as our cable TV provider and must use the DVR the company provides (and charges for.)
Have you checked the policies of your TV service provider regarding the use of DVRs not provided by the service company?
Dec 21, 2017 | Philips DVDR75 DVD Recorder
The other day my plasma was on and everything was fine. Connected to it is a charter DVR. Suddenly the picture and sound went out. I have a PS3 also hooked up to it and it displays and sounds fine. I...
Most likelly it is your DVR that has a problem. Their are a lot of issues with those DVR's from the cable or satellite companies. I would recomend swapping it out.
Jun 08, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
I lose my audio often for non-hd channels with dish 622 dvr
The problem could lie in youir HDMI cable, this is a common issue. if you swap HDMI cables and still have the same problem then bypass your A/v rec and connect your 622 direct to your tv and see if the problem persists, it it does, then your DVR needs to be replaced, you can call dish for addition troubleshooting if it is in fact your DVR.
Nov 10, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Vip 622 rebooting. receiver works when just plugged in,once satellite cables attached, will work for a while then reboots. Can get it going again if take satellite cables off then put them back on. But if...
this problem occurs when the ground on the Dish is not properly connected. What is happening is the cables from the dish are backfeeding voltage and grounding out your rec. Now there could be a possiblity that it could be the rec. however if it stays powered on with the sat in cables discon. then it defintley sounds like a grounding issue.
Oct 20, 2009 | DISH Network ViP622 DVR DTV Receiver /...
I lost 60 hrs. of recording time in less than 24 hrs. on VIP 622
Remove all the External Storage devices, make sure that you Un-Plug them Completely including their Power. After Resting the Dish Receiver, Plug-In everything back on and try.
Mar 16, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Off Air?
The Scientific Atlanta box was a cable box and recieved CATV signals. The Direct TV box is satellite only. You might check if it has a built in ATSC tuner for off air digital signals. Direct TV in most locations offers the major networks in HD format.
Jan 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Connecting a Dish 622 Receiver to the HTR500 and a Sony HDTV TV
I haven't researched to actual manuals for your equipment, but I'm guessing that the optical may be disabled when the HDMI is used. You could try using the component video outputs to the TV and then the optical to the Onkyo.
Jan 02, 2008 | Onkyo HTR500 Receiver
DISH Network ViP622 DVR  DTV Receiver / 180-Hours Video Recorder Logo
106 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Sheldon Dedek
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
