Question about Nextar M3 Car GPS Receiver
Nextar GPS Never acquires GPS Signal
Never acquires GPS Signal . Every once in a while (every few hours) it may locate the signal, but then it loses it. This is a useless device as itts working now.
  • Anonymous Feb 12, 2010
    Yes, I have a Garmin Nuvi now which I got to replace the previous Garmin I had that someone stole. Garmin work great, this one must track to a lousy or now non existent satelite. Want to sell this but not if it won't work, it's only use is as an MP3 Player and Photo Viewer as it stands now. Thanks for your reply. The Nextar site was useless.
odiebugs
    President:
  • 949 Answers
The only thing you can try is the external antenna for this unit.
You could be in an area that has poor signal.
If it where me, I would go to a place that I could return a unit,
I only use garmin, there hand-held unit's are the top rated for
the frequency of getting satellites.
So say you have a walmart, see if you can return a unit, buy a garmin
and see if it get better reception, and if it doesn't then its not the unit.
If it does,sell you old one on ebay.
Posted on Feb 12, 2010
  • odiebugs
    odiebugs Feb 12, 2010
    It might work better for someone if they had the external antenna.
    There site is bad, and I don't like there products, but I try not to
    express by beliefs about products.
    You could be honest and sell it and say the rest is great but the gps
    is poor, hey a few dollars is better they letting it go to waste ,or maybe a friend could use it.
    Thanks for the reply.
I have a Garmin Nuvi 300 model and from last few days its not picking the satellite signals when I open the antenna, it keeps saying searching for satellitie signal. What could be problem & can it be...
Hello there,
As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes. If your unit has not been used for an extended period of time (more than a month), it may take 3-5 minutes to acquire satellites. If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal. If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased. If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions. If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites. If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*. If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
*Note: Some units may not be compatible with an external antenna. Please check the Compatible Devices tab on the external antenna's page to see if your unit is listed.
Hope this was helpful to you. Goodluck Elect_Comp
Sep 01, 2011 | Garmin GPS
I have a 1475 Magellan GPS which will not acquire the signal. My unit was on for over four hours last night, trying to acquire the satellite signal. How do I solve this problem?
I can understand the problem in the unit, so to over come this problem you have to reset the unit .When you reset the unit surely the unit will it acquire the satellite signal also it show your current location.Follow the steps to reset the unit :
On the left hand side at the lower bottom coner you can see a small pin hole there named as reset .Just insert a paper clip in to the hole when the unit is on.this is the way to reset the unit......
Feb 18, 2011 | GPS
While driving Garmin Nuvi 250 constantly loses satellite signal. The screen says that it is aquiring a signal. It is also constantly refiguring the route.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
Nov 12, 2009 | Garmin nuvi 250 GPS Receiver
No signal in two units, did reset with magellan tech service, still gets stuck in the same location and no signal
Plug it in, turn it on and let it sit out in the open. If the unit is working at all, it will eventually find and lock onto the satellites. The 760 I'm using now came from California and it took over 2 hours to lock on. When I start a trip now, I let it sit before starting to drive and it locks on in just a few minutes.
Oct 27, 2009 | Magellan Roadmate 760 GPS Receiver
GPS Lost Signal for a few months
This is taken from the Nextar Support Web Site;
Q: NOTICE for all US customers with M3 and Q4 series that have been having a problem recently with receiving a satellite signal.
A: Recently it has come to our attention that there has been a problem with a US GPS satellite, in the early morning of June 14 launch a sudden change in the code signal, leading to some GPS signal anomalies. It is told that the satellite signal should be running properly by June 22, 2009.
Jun 23, 2009 | Nextar Q4-04 Car GPS Receiver
No GPS Signal yesterday 15th and taday
I can't solve this. But it is happening to me, too. I probably know about as much about the satellite systems as you do. I've got an older aviation GPS I have not tried, yet. Did nextar indicate what Satellite was down and why the GPS would not acquire a different satellite.
Jun 16, 2009 | Nextar Q4-04 Car GPS Receiver
Magellan roadmap 760
The Magellan 760 has been around for a few years now, and unfortunately, isn't one of the fastest units around when it comes to synchronizing to a satellite. I find with mine that the time it takes to lock onto a signal depends on several factors:
1) Having the GPS mounted in a way that allows the antenna to have a clear view upward 2) Having my vehicle in the open, so that the signal isn't impaired by adjacent buildings, overhanging trees, etc. 3) Being stationary while the GPS attempts to get a lock. It has more problems locking while moving. 4) Ensuring that the GPS is used frequently, as it loses its memory of what satellites it's synchronized with if you happen to be in a different place when you turn it on than the place you were at when you last turned it off.
Those last two points have the most affect on my GPS's performance. I find that by turning on the GPS and just parking in my driveway or parking lot for a few minutes will allow the GPS to acquire a signal in a much shorter time than if I start to drive immediately. While this will waste a bit of time on the front end, it does help you get synchronized more quickly
May 27, 2009 | Magellan Roadmate 760 GPS Receiver
Garmin 260w won't acquire satellites
Jan 30, 2009 | Garmin nuvi 260W GPS Receiver
NEED A MANUAL CAN NOT FIND MINE
they only have the quick start guide available on their website here-
http://www.nextar.com/frontend/support.asp?CATEGORY=10000312&MODEL=X4-T&subpr=482252903&categ=
you should call and see if they will send you a replacement.
United States/Canada
Hours of Operation | Monday to Friday 8 a.m. to 9 p.m. EST (closed on holidays)
Phone | +1 (888) 849-0846
Fax | +1 (951) 602-6047
Email | [email protected]
United Kingdom
Phone | 0800-047-0126
Mar 25, 2008 | GPS
Nextar M3 Car GPS Receiver Logo
356 people viewed this question
Top Nextar GPS Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Nextar GPS Expert? Answer questions, earn points and help others
