Question about Onkyo TX-SR501 Receiver
Sound cuts in and out - Onkyo TX-SR501 Receiver
Posted by rremboldjr on
Anonymous
    New Friend:
    Problem Solver:
  • 5 Answers
Is it going into protect mode???
If so, check your speaker connections. Make sure that the wires are spliced clean and no hanging copper wires are there at the receiver and the speaker.
Posted on Feb 13, 2010
Sound keeps cutting out
take to the repairers they will handle it parfectly
Sep 05, 2017 | Toshiba Satellite L755s5246 Laptop...
Mackie 450v1 when i turn on low cut switch the sound stops turn off low cut and sound returns
Dusty/Faulty switch and/or opamp inside pcb, let me know to help more/.
Jan 03, 2012 | Mackie SRM-450 System
Magnavox rear projection tv - sound cuts off when
Problem with SSB module and will burn out a resistor on SSM board eventually and will have no sound at all.
Apr 12, 2010 | Philips Televison & Video
The sound cuts out all the time for a second
you might have a short in your wiring somewhere. If your power wire touches any kind of metal it will ground it out causing it to cut off.
Oct 31, 2009 | Car Audio & Video
5.1 Surround Sound Cutting Out
HI,
Yes you are right man, this problem occurs only with the cable problem, i can explain you, if there is a receiver problem means you won't get the sound its dam sure,
only if there is a cable problem you will get some noise or sound cut off with the speakers, so you please check the cables properly it will be alright.
Mar 26, 2009 | GE GTD120 System
Amp gain problems!!!
is more than likely a loose connection
Jan 18, 2009 | Earthquake Sound PH-D2 Car Audio Amplifier
My Hitachi TV model # 57f710s doesn't have picture or sound.
It very well could be the flyback unit around 70.00 for part!
Dec 07, 2008 | Televison & Video
Onkyo TX-SR501 Receiver Logo
147 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
