Question about HP LaserJet 1320n Printer
Trying to set up LInksys WPS54G, connected as
Trying to set up a Linksys WPS54G using a hp1320n (need the wireless function), connected as advised inc ethernet cable, inserted cd, come to select device and table just blank, its as if the unit doen't exist. however all the lights are on and green, can any one help....
I run Zonealarm and am using linksys router if this matters?
Posted by alister_eyre on
  • Anonymous May 11, 2010
    Are you trying to set the printer up as a wireless printer?
Anonymous
    New Friend:
  • 78 Answers
By default ip address of linksys is 192.168.1.1
to star config you need to be connected with ethernet cord rj-45
or conenct via wireless by conencting to linksys on wireless
admin user: blank
admin pws: admin
*choose a protocol on your linksys router on internect conenction type:
check isp protocol :
dhcp: needs serail number of mac address
it picks up automatic
pppoe: needs username and pws from isp
*the ip address has to be diferent from the isp modem:
isp modem 192.168.1.1 linksys 192.168.1.1 incorrect
isp modem 192.168.1.1 linksys 192.168.2.1 correct
change the ip on lan settings on your router
*wireless: ssid by default is linksys
ssid: linksys
wep : none
to setup wireless
access the wireless basic
change the ssid to any network name
enable the wireless password
choose wireless security
enable wep key 10 digit hex pws
make shure you saved settings on every settings
Posted on May 01, 2010
1helpful
Linksys wrt54g, need console on pc but dont have disc
Are you trying to connect the Xbox to the wireless network?
If yes then you will need to check the wireless settings of the router.
is there any computer on line using the router ?
on that computer you can open the setup page of the router. check the wireless ettings and the security settings then try to connect to the wireless network on the Xbox.
See if that works.
Click here for more information
tip
WPS54G Printer Server Setup
I bought a Linksys Wireless-G WPS54G printer server and trie to put it in my home network. Following the instruction from the manufacturer and spent many hours, I still couldn't make the printer server work. There was no problem to get the IP address from my DHCP server using the wired connection. But when I pulled off the network cable and tried the wireless connection, I got "connection failed" error at the last step to install the printer server. I checked my router's client monitor and found the printer server did get the dynamic IP address wirelessly. When I pinged that IP address, there was no response at all from the printer server. In another word, the printer server couldn't communicate with other devices in wireless mode in the network. I searched the Internet and found there were many users had same problem and couldn't resolve the issue even from the manufacturer technical support. As a last resort before I was going to send back the printer server, I switched the network router to one of a different brand. My previous router was manufactured by BUFALLO INC and the new one was made by D-Link. After I rerun the installation following the instruction, the "connection failed" error was gone. The printer server could work finally.
The tip here is: Try a different brand router when there is a connection failure problem for installing the WPS54G printer server, if possible.
My linksys WPS54G print server no longer works since I bought a new router, a linksys WRT54G2 router.
your using same information ssid and wep
chanell 11
b+g mix
my email to follow up
i work for linksys and verizon internet
Trying to set up my Mac to print via a linksys wpsm54G wireless print server. No luck so far. Any advice?
the disc won't work with mac - but you can do LPR on it but if you do LPR it will only support printing not scanning and fax.
2answers
Compatibility
That is correct ..that print server does not support bi-directional functions.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
1helpful
I have a netgear wireless network. I am trying to
you can use sharing printer.. even your are using wireless can print as long as you are connected on that network and secondly the same name of workgroup.
1helpful
Linksys Wireless G Print Server set up
Hardwire the wps54g to the router and disable all firewall installed on the compute.
Linksys wireless print server WPS54G - wireles network problem
access your router and go to wi fi settings check is it enabled if not enabled it.
Also check its netwrok settings like dhcp , ip addreses , subnet mask gateway.
Also check in your network that in gateway is always your linksys ip.
Let me know .
Problem with Linksys Wireless-G WPS54G Print, PS can't be found.
Check the settings on your wireless print server. And as well check your router.
1helpful
Upgrade failure
The software that came with the WPS54G model is not (yet)compatible with Vista systems. This model is not listed on the Vista-ready devices from Linksys' website (www.linksys.com/vista). The behavior more likely a result of a software incompatibility.
For PrintServer network setup, you may still use the CD on a non-Vista system (XP, Win2000 or lower). Or, by installing it manually by accessing it's web interface.
To make your Vista working with the printserver WITHOUT the use of the PrintServer CD, do the ff:
1. Make sure PrintServer is configured on the network with the same wireless settings of your router and with a manually assigned IP address which is in range of the router's IP segment.
2. Make sure that computer can print locally to the printer (e.g. via USB connection to the printer).
3. When computer can surf the net and connected to the router's network (wired or wireless), follow the steps from this article and make sure Printer is showing up as Online.
HP LaserJet 1320n Printer Logo
Vinaya Kumar...
Vinaya Kumar...
Ekse
