Landice L7 LTd Pro Sports Trainer Treadmill Logo
Posted on Feb 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Landice L7 gives me a L5 reading on the screen
Landice L7 treadmill gives a L5 Reading on the screen
  • Anonymous Mar 20, 2014
    My landice is giving me the replace safety key code, can you please help me find it
John Mazmanian
Level 3:
President:
  • Landice Master 832 Answers
  • Posted on Feb 28, 2010
John Mazmanian
Landice Master
Level 3:
President:
Answers
832
Questions
0
Helped
628142
Points
2056
Your L7 error looks like L5 , but its really LS which mean lost signal. Unplug unit take motor shroud off then plug unit back in wall outlet. When looking in front unit you will see a Motor control board and there are LED lit up one of them should be an amber light this is you speed sensor which is attached to the top of your motor. Manually rotate the fly wheel and see if that light flickers if it does then your speed sensor is working properly if not replace speed sensor. The next thing to look at is the motor brushes to if they are worn unplug unit you should see slitted caps on both side of motor remove them if they are less than 3/8" they need replacing. That for the most parts should take of your problem. Call Landice @ 1800-526-3423 have the serial# handy their on all the components in the unit
  • George
    George Mar 08, 2017
    Hi John, this was very helpful. My speed sensor appears to be fine and i have plenty of brush left on each brush. Any suggestions on where to look next?
Landice L7 Problems. It runs fine until drops below 2 miles per hour and then it stops for 2 or 3 seconds and starts back up for 2 or 3 seconds.
It sounds like you normal routine has made the motor hot and then when you slow down the residual heat is causing the motor to cut out. Check the vents in the motor for fluff or blockage.
https://www.google.com/search?q=Landice+L7+treadmill+stopping+at+cool+down
tip
OS or O5 Error on Landice L-Series Treadmills
Probable Cause
An OS or O5 error on the Landice L-Series treadmills, such as the L7, L8 and L9, indicates an over speed condition and this occurs when the actual speed of the running belt is faster than the set speed. The possible causes for an overspeed, OS or O5, error are: A) User weight is over 200lbs, treadmill elevation is set between 10% and 15% grade and speed is set between .5 mph and 3 mph
B) User is pushing against treadmill belt causing it to go faster than the set speed
C) Defective lower board or misaligned speed sensor
D) Maladjusted speed potentiometer
Corrective Action
A) Gravitational force will enable the user's weight to move the treadbelt faster than the set speed. The speed sensor will pick up this increase in flywheel speed and sends this information up to the display electronics. The microprocessor will then compare the actual speed to the displayed speed, determine a runaway speed condition and shut the treadmill down. An overspeed will display in the window. This is a safety feature built into all treadmills that utilize closed loop speed circuitry. The way to address an over speed condition due to gravity is have the user decrease elevation below 10% or increase the speed.
B) Similar to the gravitational force, a user can be holding onto the handrails and pushing the running belt in such a manner where they are using the treadmill like a manual machine rather than a motorized one. User needs to set speed compatible for their actual walking or jogging speed so they are not pushing the belt.
C) It's possible a blown motor control board is the problem. This occurs more frequently with PWM drives than SCR drives. However, this problem is becoming rare due to the PWM circuitry which senses this condition and shuts itself down before the drive motor receives any DC voltage at all. This means you'll get an LS or L5 error if your PWM is blown, not an OS or O5 error. This is a safety feature on all Landice home treadmills with PWM motor control boards. The SCR motor control boards also have internal protection to prevent an over speed condition from occuring due to an internal component failure. In the rarest of cases, on home treadmills, a faulty relay board can cause an OS or O5. To verify this, using a digital voltmeter, with treadmill turned on, measure the DC voltage between the V+ and P1 on the PWM board. The reading should be between 6-7 VDC. Also measure the DC voltage between P1 and P2 on the PWM board. The reading should be between 0.5 VDC and 6-7 VDC. If either of these voltages measure zero, replace the relay board.
D) Get into Open Loop Speed mode and check the speed. Adjust pots as necessary to bring up correct speed for max and min.
http://www.sportsmith.net/support.aspx?did=BAB0DA9A-857E-41B3-A1DD-3DC0663BB9A4
My landice 8700 programable is showing an L5 error and does not run how do i replace the switch that is bad with this treamill it only has an up and down button for more or less speed
LS Error on Landice L-Series Treadmills with Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. This error can occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:A) Speed sensor is out of adjustment
B) Speed sensor is damaged or faulty
C) Display cable is damaged or faulty
D) Improper speed control wiring Corrective Action A) Speed sensor should sit parallel with the flywheel and gap between speed sensor and flywheel should be within 1/16". Adjust speed sensor if necessary.
B) Inspect speed sensor connector to relay board. Check for pushed pins or loose wires. Repair or replace speed sensor assembly if necessary.
C) Inspect upper harness or display cable connector to relay board. Check for pushed pins or loose wires, giving specific attention to pin 5 (brown) and pin 9 (green). Repair or replace display cable if necessary.
D) Inspect speed control wiring:
  1. Checking purple wire from V+ on pwm board to P3 on the relay board
  2. Checking orange wire from P1 on pwm board to P1 on the relay board
  3. Checking brown wire from P2 on pwm board to P2 on the relay board
  4. Confirm P3 on pmw board has no connection
Correct speed control wiring if necessary.
Details about LS Error on Landice Series Treadmills with Belt Movement
I have just purchased a Landice P 7 Pro Trainer and notice that a light is constantly on in the front part of the machine where the motor is located. Is this normal? Also, I am having difficulty inputting...
If no error number as "L5" should work well, with respect to the LED light is normal if you have more questions please send me a E-mail to [email protected] I have the technical manuals, I will be going up soon FixYa.com
Treadmill does not start
is a problem with the speed sensor or card connectors are specifically where the motor cables is false or welding is damaged if you can not check you should call a qualified technician to review these two parts and repair.
Error code L5 on schwinn 820p
Landice L9 tredmill, L5 display on screen,belt runs slow and nothing else works to the touch.
I have a Landice L8 and the error code L5???
Landice treadmill 05 error code comes on when i hit start
Top Landice Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Sportsmith LLC
Sportsmith LLC
ADMIN Andrew
ADMIN Andrew
Are you a Landice Exercise and Fitnes Expert? Answer questions, earn points and help others
