If your laptop has the correct connection you dont' need any software. on the laptop look for the Fn key usually lower left of the board. hold that down and look to the "F" keys at the top of the board for a picture of a monitor or word LCD. hit that. this will toggle the display mode.
if this doens't work leave the monitor on the unit. turn the unit off and then boot back up. this will auto recognise the monitor. further advanced options can be foudn in your display setting area of the control panel
ERR1
indicates a speed issue. In this case, the motor speed as reported
from the optic sensor differs
from
the speed setting.
Analysis:
Optic sensor signal issue -- Either the optic sensor signal is not
right, or it is read incorrectly, or
the
signal is not reaching the display.
test the speed sensor for open or faulty. clean it, and tight the connector very well. see the diagram attached. However RUN the software calibration for easy fix it.
God bless you
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Once you connect external monitor, you need to transfer the display in to it. for that you need to press Fn key and some other key( a key with monitor symbol on it) . If you mention which laptop you are using we can help you out.
