Expert
- Posted on Feb 17, 2010
Re: My ricoh 3235c copier had image problem, one inch...
Try cleaning the blade(by rubbing a piece of paper between the drum and the blade) ,also clean the charge roller(black rubber roller) with a soft clean cloth.If all else fails replace the black drum unit(It's life is 60k)
Thanks for responding, there is 1-2 inch strips
when printing with black toner.I replaced the developer unit, but black/grey streaks remain
There is tonner on the drum in the same area, it is not being cleaned.No message or error code.
Thanks
Dave.
Which color? And what is the message now , replace cartridge or add toner?When you removed the old developer unit did you see any mark on the unit where there is toner(less toner)?Any gears broken?
