Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
Posted on Feb 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am getting red shadows. the converge mutiple
I am getting red shadows. the converge mutiple point is off.
Chi Chu
Level 3:
  • Philips Master 8,457 Answers
  • Posted on Feb 12, 2010
Chi Chu
Philips Master
Level 3:
Answers
8457
Questions
0
Helped
2821052
Points
26282
Convergence is dead.Must replaced 2 convergence ICS.U know how to solders?Tries these Websites Tv repair World.com,Tvrepairkits.com for convergence kit to repair it ur self.The shop will cost U $300 for parts and labors.
3answers
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Mitsubishi RPTV has a blue shadow/image alignment problem
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
1helpful
46'' philips rear projection tv, red shadow
Thats caused by failed convergence ICs. You can get the DPTV305-DPTV345 convergence repair kit from www.tvrepairworld.com which also applies to your model. The kit contains the parts and the CD with instructions.
Red shadow on tv
If this is a projection tv a shadow usually indicates bad convergence. If you cannot adjust convergence from customer menu have a professional replace convergence amplifiers and reconverge
2answers
Image on tv casts a red shadow.
TRY THE MAGIC FOCUS BUTTON. IF THIS DOES NOT CORRECT THE PROBLEM YOU WILL NEED A SERVICER TO GO IN AND REPAIR CONNECTIONS OR REPLACE THE CONVERGENCE IC'S AND OR RESISTORS. AND READJUST CONVERGENCE IN THE SERVICE MODE.
Red horizontal convergence PT-47WX49E
converge outputs getting tired or limiting resistors opening up. adjusting this incorrectly will make the situation worse keep in mind that overdriving these chips will cause a fold over of your image when you see this carefully adjust in the opisite direction as you may be overheating the outputs
I have a red and blue shadow in my picture
IT sounds like it needs to be degaused.
Before checking this, check for speakers placed by the set. this will cause it too.
The best way to avoid this situation is
  1. Don't place unshielded speakers near the set.
  2. Don't move the set while it is turned on.
The coil that is used is about $50 and can sometimes be found at industrial electronics stores. It's called a degausing coil. most TVs have a version of this built in and mutiple power on/off/ons may fix it, but don't hold your breath...
The trick is to turn the coil on with it right up to the screen. Move the coil in a big circular motion parallel to the screen as you S-L-O-W-L-Y move away from the screen. when you are as far away as you can get [about ten feet] turn the coil off. Caution. KEEP HARD DRIVES, CREDIT CARDS, AND FLOPPY DRIVES AWAY from the energized coil!
Good luck
Ken
Samsung hdtv has a problem
this points to a convergence amp problem. in customer setup do you have and control or movement on convergence adjstment
Maganvox TV with red-shadow to picture
Hi Emily,
Your TV has bad convergence amplifiers. They are large integrated circuits that are mounted on large metal heat sinks. They have a part number on them, but might be covered up by a bracket. The part number should start with STK. They are replaced as pairs. You will have to find someone with the skills necessary to replace them.
Best Regards,
MyTvGuy
Convergence problem
does it cast red shadows on the picuture.. red shadows around letters. might be the red convergence or could be the read yoke has come loose
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
