Not knowing the age and model of your emachine I will give you a few choices.
If it's an older series like the picture above you should be able to go into the start menu, all programs and then either PC Help and Tools or Emachine-Recovery manager. Then select Recovery Disk Creator.
If it's a newer model, Emachines and Gateway were bought out by Acer over a year ago and now use the Acer style recovery. Select Star, All Programs, then Emachine Recovery Manager. Load the Disk Creator selecting Factory Default disks first then selecting Application and Driver Disk.
One note, if it's an older model you will only be able to create the application and driver disk. It would have came factory with a base windows install disk. If you have lost this disk, you can reinstall using any standard OEM disk for the correct version of windows and using the windows license attached to the computer, but you will need the application and drivers disk to install your devices and programs.
If it's and older model and you can't find the disk, you can order a replacement set by contacting Emachines support, but there will be a cost invloved.
Testimonial: "Thank you so much for taking the time to answer my question, I found it and following you instructions now. Thanks for the assistance. Helen"
SOURCE: I bought a ET1331G-03w at Wal-Mart. I want to
What type of disks are you using? You cannot use DVD RW. You need to use DVD - R . I have had this very issue. Hope this helps.
PS, once it tries to write to a dvd and fails, try a new one.
Testimonial: "Young Lady; You hit the nail on the head! I haven't been able to keep up with the new tech. It's great to learn help is a call away. Much thanks!!"
Click the "Start" icon on the Windows Vista home screen. Select "eMachines," then click "eMachines Recovery Management." The eMachines Recovery Management program opens.
Click "Create Factory Default Disc." The program will tell you how many discs you will need. Make sure the correct optical drive is selected, then insert a blank disc into that drive. Click "Start" to begin the burning process.
Remove the disc when it is finished burning and label it "Recovery CD 1." Insert the next the next blank disc if one is required. Click "OK" to begin burning the next disc. Repeat this step until all of the discs have been created and labeled. Close the eMachines Recovery Management program, insert the system CD that came with the laptop and restart the laptop.
Press "F12" repeatedly when the eMachines logo is displayed on the screen to be redirected to the Boot menu. Select the optical drive, then press "Enter."
Insert Recovery CD 1 when you are prompted to insert the recovery disc. The eMachines Recovery Management program will open.
Click the "Restore" tab in the list on the left side of the eMachines Recovery Management program window, then select "Completely Restore System to Factory Defaults." The computer automatically restarts and the recovery process begins. Insert any additional recovery discs as requested. The computer will reboot automatically when the laptop has been recovered to its original factory default settings, and you will be taken to the Windows Setup screen.
Set up Windows Vista with your own personal settings.
