Question about Zanussi FJS1225W Front Load Washer
Yes but NO .you only have one inlet valve on this model and if you connect to the hot water supply your washing would be rinsing in hot water and come out all greased. Also would not be economical to do this ..
Posted on Feb 12, 2010
Hi
This
error code indicates a water pressure concern. Not enough water is getting to
the machine in the proper time frame. There are a number of reasons this may
happen and some of them can be extremely easy and quick to fix.
One of the easiest solutions is to check both the hot and cold water shut-off
valves and confirm that they are open as far as they will go. Perhaps the last
time someone check the hoses, or moved the washing machine the handle was left
off or only partially opened and the F20 error code will appear. Make sure to
check both the hot and cold water faucets.
The
second option is that you may have a defective hose. If the host has become
kinked or in some other fashion damaged it may be stopping or slowing water.
Please get back to us if you have further query else please accept the
suggestion.
Thank you for contacting fixya.com
