In your Phone's Applications menu, there should be an option to get more applications or something of the sort. Just click on that and it should take you to a website on your cell phone that will allow you to download and install new software. Most carriers charge for extra applications though.
Here's a site you can check out. Even though your phone isn't a pocket pc, this commnuity should help you out a lot.
Hi. There's no default dictionary as far as I know, but here are some examples for you to download: (http://pocket-pc-dictionaries.penreader.com/) , (http://www.ebswift.com/PocketPC/WordNet/). You can download these and try them on your device. Hope this helps.
I think that “Microsoft pocket pc 1996 - 2003 os” called now “Windows Mobile 2003”.
To upgrade your PDA to 2003SE please go to TOSHIBA Site
http://www.toshiba-europe.com/. Than go to Computer systems.
Under “Support &Downloads” there is option Download Drivers. Please chose your PDA and there are all useful Drivers for “Windows Mobile 2003 SE”. In every zip File there is “Upgrade Guide”. Read it. It can help you to make update without problems.
Section A - How to use a Toshiba Pocket PC e740 without loss of data:
Never let the battery fully discharge.
Never disconnect the battery from the e740.
Regularly backup your stored data.
Always connect the product to an external power source before changing the battery.
Section B – How to backup your data:
B1 – Using Activesync
You can make a backup of the Toshiba Pocket PC e740 data to your notebook or desktop computer. If you have backed up your data to your notebook or desktop you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended.
The following types of data can be backed up:
FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program.
REGISTRY: Setup information of Windows or programs.
DATABASE: Database information from Pocket Outlook.
When making a backup or restoring data please DO NOT remove the Pocket PC e740 from the USB cradle and DO NOT turn off the power to the device until the backup or restore is completed.
Backup Instructions:
Insert the Toshiba Pocket PC e740 into the USB cradle.
A connection between the e740 and your notebook or desktop will be established.
Please close all active applications on the e740.
On your notebook or desktop start Activesync and select Tools and then Backup/Restore.
Select Full Backup.
Select Back Up Now to start the backup process.
B2 – Using a Compact Flash (CF) or Secure Digital (SD) Memory Card:
a) How to insert a Compact Flash Memory Card:
Ensure the e740 is connected to the mains.
Turn the e740 off.
Remove the dummy card if necessary.
Confirm the direction of the Compact Flash memory card by lining up the side grooves of the card and groove edge of the card slot.
Insert the card smoothly and completely.
b) How to insert a Secure Digital Card:
Turn the e740 off.
Insert the Secure Digital card with it’s contact surface (the metal contacts) facing the back of Toshiba Pocket PC e740.
Press the card down until it clicks.
You can make a backup of the Toshiba Pocket PC e740 data to your Compact Flash or Secure Digital memory card. If you have backed up your data to your Compact Flash or Secure Digital memory card you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended.
When making a backup or restoring data using the DataBackup program please DO NOT remove the Compact Flash or Secure Digital card from the Pocket PC e740 and DO NOT turn off the power to the device until the backup or restore is completed.
Backup Instr
