Question about Bose Audio Players & Recorders
How do I wire the speakers to tuner and then to subwoofer?
Posted by jsather353 on
Anonymous
    Novelist:
  • 128 Answers
Depending on the subwoofer you have there are several ways to do this.
If you have an amplified subwoofer and a receiver with a sub out then just run a RCA cable from the sub out to the input on the sub. depending on the sub you may need a Y adapter to provide a signal to both the left and the right input.
if your sub has high level (speaker terminals) for inputs AND outputs you can use speaker wire from the receivers front speaker terminals to the sub and then from the sub to the speakers. You would use this same process if your sub does not have a built in amplifier.
Take note that if you do use the receivers subwoofer output its often necessary to turn that output on using the receivers on screen menu.
Hope that helps
Posted on Feb 12, 2010
Subwoofer not recognized and no sound from tuner
do a test tone which will test all speakers connected to the receiver.
Apr 19, 2014 | Yamaha Audio Players & Recorders
I am hooking up a pioneer super tuner d. It has an illusion wire and a positive dimmer wire. What are these wires for?
You need a hot wire red and a ignition wire yellow and ground for power. Hope this helps plus the speaker wires. Hooked up. If using a amp then you would use the blue wire for a remote wire to amp.
Jun 24, 2011 | Pioneer Car Audio & Video
Need a wire diagram for pioneer DEH-1100 super tuner
Usually it's....
black = ground
red = switched battery power
yellow = constant batery power (for clock...etc)
orange = illumination
blue = amplifier turn on or accessory (electric antenna, amps etc)
green/white/purple/grey are speaker wires.
Apr 25, 2009 | Car Audio & Video
How do I connect my AR subwoofer to the tuner?
If your tuner has a sub out you use that together with a single rca cable for the signel
Jan 02, 2009 | Acoustic Research S108PS Subwoofer
Wiring diagram for a pioneer super tuner 3
What model of Pioneer? Super Tuner 3 is just the type of radio signal receiver that the unit has. Give me a model number.
Jul 16, 2008 | Car Audio & Video
Kenwood receiver/sub problem
The amp's remote turn-on wire is probably connected to the blue wire coming from the back of the stereo - this is intended for a power antenna, which is why it only works when listening to the radio. Disconnect it from the blue wire and connect it to the blue/white wire coming from the back of the receiver and you should be good to go.
Sep 21, 2007 | Kenwood KSC-WD250 Car Subwoofer
Orange light
I have the same speaker and it sounds like its behaving properly.
if you look on the back of the amp, you will find a switch that allows the speaker to automatically switch the speaker on or off based on the level of the audio coming from the tuner that it is attached to. If the switch is set to the auto mode, then it will listen for audio on the line and if the signal level coming into the subwoofer is high enough, the amplifier in the subwoofer will turn on and play. If the signal is not strong or loud enough, then the subwoofer will not turn on. There are two solutions to getting the speaker to work.
1. When you turn on the tuner or audio source that is feeding the Subwoofer speaker, you will need to turn it up loud enough to trigger the circuit in the subwoofer to switch on.
2. Alternatively, you can bypass the automatic circuit and set it to the "ON position all the time. In this position the subwoofer is always ready and waiting and should play any signal that is fed to it regardless of the loudness or volume of sound from the tuner. The switch is located on the back of the speaker cabinet just to the right of the red and black speaker wire connections. It is labeled "AUTO" and the switch positions are labeled ON and OFF.
Hope this helps!
Jul 09, 2007 | Acoustic Research S112PS Subwoofer
NO Sound Except Subwoofer on Disk Playback
guys wrong iso adapter.go to propper audio shop
Oct 11, 2006 | JVC KD-AVX2 Car DVD Player
290 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
