Question about Alpine CDE-7870 CD Player
My alpine CDE-7870 Cd player stopped working and i cant find out what is the matter with it
Posted by oldfart658 on
Poppy Chulo
  • 863 Answers
The power line has a blown fuse. Check under the dash or wherever the fuse box is that controls the stereo. Also, check the inline power wire cause they have those little cylindrical fuses that blow. Also, make sure you got a good ground and check for shorts.
No not your shorts. Check for shorts in the wiring.
Posted on Feb 12, 2010
I have an Alpine CDE 7870 and it will not work when my car is initially started. I cuts in & out until the car has been running for about 15 minutes and touching any of the buttons during this time...
It sounds like you could have switched the accessory and constant power around. Try switching your red and yellow wires around. You might also have a bad ground connection. Try grounding it to a different spot. Make sure it is connected directly to a piece of metal that is connected to the frame.
Apr 23, 2011 | Alpine CDE-7870 CD Player
How do i remove the Cd player from the dash?
Alpine uses a non proprietary set of pins on each side of the deck. To get access to them you will need to remove the faceplate. Then remove the thin plastic trim from around the din chassis.
Normally using a butter knife or another thin piece of metal in each side between the deck and the DIN enclosure will allow you to depress the locking pins, then slide the deck out of the chassis.
Jul 06, 2009 | Alpine CDE-7870 CD Player
How do I set the time on an alpine cd/radio reciever 7874?
Check out the owners manual, here's the link to copy and paste in your browser search.
www.crutchfield.com/ISEO-rgbtcspd/p_500CDE7870/Alpine-CDE-7870.html?c=3 - 47k
Mar 26, 2009 | Alpine CDE-7870 CD Player
Heating up on back of cde 9852 alpine cd player
try to chek the regulator or replace it and install a heatsink for him
Jan 31, 2008 | Alpine CDE-9852 CD Player
Alpine CDE-7871E - Head Unit now not displaying any LED
Check the leads from the heat sink on the back and my guess is the contacts between the faceplate and the actual head unit are not doing so well. This is a detachable face unit right?
Nov 29, 2007 | Alpine CDE-7870 CD Player
Alpine CDE 9881
You must have a faceplate from that exact model, no others will work. You can try to contact Alpine for a replacement. If it is any consolation, someone has a useless faceplate, because it won't work with anything else, either. Try running an ad in your local lost & found column, you just might get lucky, especially if you offer a reward.
Jul 28, 2007 | Alpine CDE-9881 CD Player
I cant turn on "loud"
can some one how me find the loud on a alpine cde-7858
Apr 07, 2007 | Alpine CDE-7858 CD Player
Alpine CDE-7870 CD Player Logo
240 people viewed this question
Top Alpine Car Audio & Video Experts
Jeffrey Turcotte
Jeffrey Turcotte
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
