When I insert a video cassette into my magnavox dvd/vcr combo model number ZV450MW8A it turn the power off, ejects my tape, and eats the tape. What do I do to fix this problem?
Every VCR has a transport mechanism that moves the tape-when eject is hit it reverses and winds the tape back into the cassette and closes the door on the tape BEFORE the tape exits the unit.
It is not doing that so the tape gets mangled--bad belts, bad rubber drive wheel etc---all happen with age even if unit is not used much.
Parts for these are getting hard to find--if any questions post a comment here.
Had the same problem. took cover off, cleaned the recording heads. Also look on the left and right of casett chassie.You'll see to thin green strips sticking up with a black elctronic device. Chech to see if it is aimed at the clear plastic pin near the little black plastic gear in the middle. mine was out of alignment on the left one. Works know. Good luck
try this unplug and then keep finger on eject and plug back in keeping hold of eject if not work then UNPLUG and take top off video and you will see were the tape is stuck THERE WILL BE A RUBBER BELT ON ONE SIDE OF MECHANISM TURN COGS THAT BELT ARE ON ( USELYANT-CLOCK ) takes time you will see parts move towards front of video ( IF NOT CHANGE THE DIRECTION TURNING ) the tape will come out when finished
THEN PLUG IN SO VIDEO CAN RESET MECHANISM
unfortunately the tape clamp sensor is broken or worn, or could have dust or dirt obstructing it and they don't have parts for these anymore, the tape clamp sensor is like a tiny white plastic sensor only a few millimeters in size with a red eye inside the edge of the tape carriage, and needs possible cleaning, it could be something as simple as dirt inside the mechanism over the sensors, the Tv will power down when the error occurs not much you can do if a clean or high output air blow of the components don't do the trick. sometimes dirt in the circuit can cause it to do that too, ....im surprised it lasted this long actually they were great for the bedroom, i had one ages ago they are available on ebay for about $100 or under now ...Sorry i couldn't be of more help.......you may get away with disconnecting the white feed ribbon cable that powers the tape cartridge and just use it as a DVD and Tv, that should stop the error.
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming.
The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine.
Good Luck
Bill
