Question about Cameras
I have a syntek mini dvr and I need to know how to set time and date
Posted by keithleeabbo on
Anonymous
    New Friend:
The instructions in the "Time Set" directory on the supplied mini-CD say to run the "time.bat" file, then copy the resulting "time.txt" file to the root directory of the device.
That will not work if your Windows is set to the US locale for date/time! Many other locales probably won't work either. Apparently the "time.bat" file was only developed for and/or tested under the China locale. The resulting "time.txt" file will not be in the proper format nor contain a valid date and time if generated by their "time.bat" in the wrong locales!
It will only work if, at a Command Prompt (Start/Run "cmd") on your system, "echo %date%" returns a date in the format "2010-12-31 Fri" (where "12" is a month number [December in this case] and "31" is a day number - any punctuation is acceptable - it need not be hyphens). US systems generally return "Fri 12/31/2010" for the same date, which will not work for this.
Instead, one way is to simply manually create a "time.txt" file in the format shown in the instructions. It consists of a single line in the format:
2010.12.23 12:34:56
This would be for 12:34:56 PM on December 23rd, 2010, for instance.
Copy that file (which must be named "time.txt" and nothing else!) into the root directory, then Safely Remove, power it off, unplug it, eject and re-insert the SD card, turn it back on, and press the "Record" button and record a few seconds.
If you're brave, you can edit the "time.bat" file to properly handle your system. Open it into any text or code editor (NotePad will do) and look down about a dozen lines. You'll see these lines:
set b=%date% set yy=%b:~0,4% set zz=%b:~5,2% set dd=%b:~8,2% set xx=%b:~11,3%
Change the last four lines in that group to read as follows (for US dates) - changed digits are boldfaced:
set yy=%b:~10,4% set zz=%b:~4,2% set dd=%b:~7,2% set xx=%b:~0,3%
The syntax "set yy=%b:~10,4%" means "In the variable b (which contains the system date string as assigned in the previous line, "set b=%date%"), start at Character #10 (where the leftmost / first character is considered to be Character #0, not Character #1!), extract the 4 characters beginning with that one, and assign them to the variable yy."
The variable "yy" needs the four-digit year in the Common Era (aka "C.E." or "A.D."), "zz" the month (zero-padded to two digits), and "dd" the day (ditto). "xx" is assigned the three-letter abbreviated weekday, but that isn't actually copied to the "time.txt" file so there's no need to really worry about that line.
For most locales, it should suffice to simply change the starting position of the respective substring (the number between the tilde ["~"] and the comma [","]), as I did above.
The %time% string is earlier assigned to variable "a" and broken down into 24-hour hour (hh), minute (mm), and second (ss), but those should be pretty much the same in most locales. The code there shouldn't need to be modified, unless your locale returns %time% in some other format than "hh:mm:ss.cc" where "cc" is hundreths of a second. Again, the punctuation doesn't matter: it doesn't have to be colons (":"). Only the positioning matters.
To adapt this to another locale, simply execute "echo %date%" at your Command Prompt and analyze it to find the starting positions of the Year, Month, and Day (remember to start counting the characters at zero instead of one!), then change the above lines accordingly.
Posted on Dec 15, 2010
  • Anonymous Dec 15, 2010
    Urk! It messed up my formatting and utterly ruined all my hard work!
    Listen up, FixYa people! We need hard line breaks in our Answer posts to be kept intact! Very often, solutions to computer problems require hard line breaks to make clear what needs to be done!
    Also, don’t muck with our Unicode characters. If I take the time to type in the codes needed to insert curly quotes or apostrophes instead of straight quotes or apostrophes, it’s because I have good reason to do so, e.g. to distinguish my punctuation from actual syntax punctuation (which would almost always use the straight ones). Ditto em and en dashes vs. hyphens. Do not turn my curly quotes into straight ones, nor my dashes into hyphens — please!!
    Frankly, I think that with these problems in place, FixYa is not a viable site for solving computer problems, and I’m sorry that I wasted my time here trying to be helpful.
Why dose recording in dvr goes on default date when light goes
Well, I'm trying to decipher this. Why does the recording in DVR revert to the default (date/time???) when the light goes off and comes back on.
I'm guessing you are trying to say time, not date, maybe day?
The DVR is trying to remember when a show comes on and record it, based on your settings. Usually shows come on at a specific time. DVRs usually update their scheduled recordings based on updated programming guide information. If you are constantly unplugging or causing your receiver to otherwise restart, most receivers will download an updated guide upon getting power back or restarting (DVRs themselves not having any idea how long they've been without power, download a new guide just in case after you unplugged them you moved to Arizona). During this time, the recording you set is showing the original time you set it up, because until the guide is downloaded, it has no idea that its wrong.
My best advice, even if I'm wrong about our language barrier here, stop unplugging your receiver. Leave it plugged in and powered at all times.
All times.
For ever.
Dec 18, 2016 | Televison & Video
What is the format for the DVR-415 time set?
You will need to connect to a PC, then open the notepad file and change the time carefully. Safe the notepad file and the correct date and time should be set.
May 07, 2014 | SWANN DVR-415 ThumbCam Mini Digital Video...
DVR-535 Genius, I am trying to set the Time and Date. the quick quide that comes with the DVR does not mention how this is done.
first of all press menu then down button to down "date and time" then press menu go down to "date input" press rec button go down to set then press rec button use press menu button till u done time snd dste setup press menu buton to home screen check the date and time in red at botton see if correct or redo as listed here
Sep 20, 2013 | Cameras
I Need to update the time and date on my vmax flex DVR
Hold down the OK button on the remote for 30 seconds. Screen will ask you to reset password. DONE!!
Jan 19, 2013 | Digital Watchdog DW-VF16500G VMAX-FLEX...
LawMate PV-AC30 manual
To set the time / date stamp you'll need your remote control and you'll need to hook it to a TV with AV inputs. Be sure to correctly select the AV input the camera is plugged into. This is the most overlooked step that causes a lot of users frustration.
I've attached a YouTube video on how to accomplish the time/date setting.
Aug 28, 2012 | LawMate PV-AC30 Wall AC Adaptor DVR...
How do i change the date to the dvr
To adjust the date and time, press the Menu button on the Remote Control, select
ADVANCED and then select DATE AND TIME
SET BY: Select MANUAL to adjust the data and time by yourself, or NETWORK to
synchronize the date and time with a time server. If you select NETWORK, then the option
of SERVER appears. Use the on-screen keypad to enter the IP address of the time server.
􀂄 DAY LIGHT SAVING: Automatically adjust the GV-Compact DVR V2 for daylight saving
time. Enter the Start and End time of daylight saving.
May 12, 2011 | Geovision GV-LX4C2V Mobile Security DVR...
L.S.My Pioneer DVR-550H does not record when programmed with the timer. After setting a timerprogram one can see the small red clock in the display but that disapears after some time and so the DVR does...
Make sure you have the right date and time set. You cannot set a timer program until you have the correct time and date set. Let me know if that helps.
Feb 20, 2011 | Pioneer DVR-550HS HDD Recorder
Changing times and dates on sprite 2 dvr
Press and hold the menu button. If there is a password set up then you will need to enter it then press menu again. The first menu page has the time and date settings on it. Use the arrow keys to highlight the time/date box that you need to change then press the up/down arrow to adjust the value.
Jan 19, 2010 | Dedicated Micros 4way 40GB DVMR wPPP w/...
Hello, I need a location to get drivers for syntek stk1160 for xp windows. thanks
http://rapidlibrary.com/index.php?q=syntek+stk1160+drivers
Sir, you can choose it from the first 4. Thank you Sir, Have a nice day.
Sep 17, 2009 | Computers & Internet
Cameras Logo
703 people viewed this question
Top Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
