Dolphin Touch cannot be read by cpu and frozen
Two problems:
1) Every time I plug the Dolphin Touch (Nu) into my computer, it doesn't read it or even recognize it! It has worked before, and the USB cable works fine (the mp3 player charges when plugged into a wall adapter).
2) How do you reset it? Every time I have plugged it into the computer, it freezes on the hour glass screen and I cannot avoid this because there is no ''Remove Hardware'' option.
Please help!
Posted by brandynlucca on
Anonymous
    New Friend:
Did you ever get a solution?i do have the same problem!
Posted on Dec 06, 2010
My dolphin nu headphones wires break
Your rough on headphones. Get a pair with Strain relief ends that are protected and stay in place when twisted or roughed up. More expensive headsets take in consideration the treatment the phones will be given and usually build them accordingly.
1helpful
2answers
My netbook have not cd. Where can I find the drivers oh Nu Tech Dolphin mp3??
Hi martacornet...
Go to the following webpage and download and intall the firmware (driver) you need, there is also a user manual there at the same webpage..
Please take time to rate me 4 thumbs up
http://www.nu-global.com/service.aspx?id=4#C_00000019
1helpful
Computer does not detect nu dolphin lite whenconected
download software from manufacturers web site then try connecting.
HI? I have a dolphin Tuch 4go Waterprooof it doesn't want to start after charge Can you help me ?? best regards
I will advice you to try resetting your device but I do't think there is a reset hole on it.
Before having your device checked at a support center try to make sure you have charged the battery for enough time then check the troubleshooting guide for this device at:
1helpful
2answers
My newly bought Dolphin NU touch 4GB has charged for over 6 hours. I fixed the headset correctly. Still it won't power on. Although when charging in the PC the screen lights up. Please help. Thx
Did you get it on ebay? My player has the same issue... And it seems to me that the seller knew about it. I haven't found a solution yet, but will probably sent it straight to NU as there is a warranty.
2answers
Dolphin pool cleaner stops working after a 15 to 30 minutes. Even though the cycle time is set to 8 hours. How can I fix ?
It sounds like you might have a problem with the impeller or drive shaft, which are both common problems with these pool cleaners. Clean around your impeller and your wheels, axles, etc. If these do not cure your problem, it is probably an issue with your electrical system.
5helpful
3answers
ITouch screen frozen on USB and ITunes
ipod touch only reads apple's usb cord are you using apples usb cord
 Grubhead
Grubhead
Marvin
Marvin
