Question about Onkyo HTR500 Receiver
I have a Harman/Kardon AVR 325. Left speaker not working with TV
I have a Harman/Kardon AVR 325. It was working fine for the past 3 years. While listening to digital cable TV (Comcast) I only get sound out of Right front speaker. Everything works with DVD, VHS, AM/FM radio.
Posted by kmckeeman on
David Dunn
    Brigadier General:
  • 8,546 Answers
How is TV audio (from the cable box) getting into the Receiver? If digitally, you wouldn't be missing any one channel on a connection malfunction, you'd lose them all. If analog, swap the channels around to isolate the problem (and reconsider using digital).
Posted on Feb 12, 2010
Trying to connect samsung smart tv to harmon kardon avr 330 with toslink cable, but i'm not gettting any sound through the receiver to speakers
The inputs may be assignable on the Harman Kardon. Make sure you have selected the proper analog or digital input type for the cable you are using. For more information, or should you have further questions, please visit my website at audioserviceclinic.com. You may contact me directly through the website. Thank you.
Dec 14, 2013 | Harmon Kardon Harman Kardon Avr 330 5.1...
No input to tv
Hi, during the last 3 years, my Harman Kardon AVR3600 has worked perfectly, but suddenly i don't know why does my unit only provide sound, and no video.
That I can do, and reset the unit, change the HDMI cable, etc... but still no video. Tkhs
Mar 19, 2013 | Harman Kardon AVR 3600
Just bought a Sharp LED TV and there is a slight delay between hearing sound and seeing lips move. Have cable box hooked up to tv by HDMI and have cable box hooked to AVR (Harmon Kardon AVR125) by optical...
Hi if there is an optical out on the television i would use that direct to your Harmon Kardon AVR 125, the sound would be in sync with picture, as the source is the same.
Jan 31, 2011 | Harman Kardon AVR 125 Receiver
PROBLEM WITH DOLBY DIGITAL ON HARMAN KARDON AV225
Well it it might not. What exact model TV?
Your high-fidelity equipment should get TV-related audio from the same place the TV gets it - Cable, DVD, BD or Sat. A digital feed each of them will carry TRUE Dolby Digital audio. There is little sense in diluting TV-related audio through a TV and it's marginal audio electronics that are usually limited to analog stereo.
May 20, 2010 | Harman Kardon AVR 225 Receiver
Harman kardon avr 325 fan motor is making a noise.
Fans are typically not serviceable. They die, they get replaced. Maybe you could look inside it and see if it has dust on it, possibly unbalancing it. Then you could assess the scope of removing it yourself. My guess is the fan may be a common variety available at Radio Shack, unless it has an internal sensor circuit for temperature or rotation speed.
Feb 12, 2010 | Harman Kardon AVR 325 Receiver
Harman Kardon AVR 325 randomly switching inputs
Step one would be to ascertain exactly what the failure mode is - which input(s) aggravate it, what kind of connection, etc. Narrow the scope a bit.
The clicking and fickering sound like it's struggling with an intermittent source connection. When it starts flickering see if you can change the problem by wiggling the cables one at a time.
Do any of your video sources have multiple attachment types connected at the same time, say, hdmi and component, but to different assigned inputs?
Apr 30, 2009 | Harman Kardon AVR 325 Receiver
My Harman Kardon AVR 254 is not responding. None
I am having the same problems with my AVR 254, did you find a solution?
Thanks
Mar 15, 2009 | Harman Kardon AVR 325 Receiver
Shutdown during exciting audio
I have the same problem also. Customer service told me to double check all my cable wires to make sure there is no short. Heck I just went ahead and unplugged all the speaker wires and then it was fine. I replaced all speaker wires and it worked for a couple days but its starting up again. i did the hard reset like the manual told me to do but the same problem.
Thats what customer support told me to do. They said it could be because its going into a safe mode. Mine is just shutting down no matter what sound is coming out of the tv or movie.
Jan 20, 2008 | Harman Kardon AVR 325 Receiver
Harman Kardon AVR 40 no sound
Check the fuses - there may be one inside the box as well. May also be a bad transformer. You can get a multi-meter at Home Depot and lookup how to check the power at the transformer.
Oct 19, 2007 | Harman Kardon AVR 100
Onkyo HTR500 Receiver Logo
242 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
