Question about Microsoft Xbox 360 Elite Console - Black
How do i set up xbox live - Microsoft Xbox 360 Elite Console - Black
Posted by mandamccandl on
Anonymous
    New Friend:
  • 65 Answers
My friend suffered like these doubts....... he cleared his problem with the help of xbox 360 repair guide...... click here for your reference
Posted on Oct 13, 2010
Anonymous
    New Friend:
  • 118 Answers
1. check your netwok calble properly
2. check your router internet connection
3. follow these steps
Accessing network settings loadTOCNode(2, 'moreinformation'); To access the Network Settings area, follow the steps for the version of the Xbox 360 Dashboard that you are using.
New Xbox Experience Dashboard:
  1. From the Xbox 360 Dashboard, select System Settings in the My Xbox area.
  2. Select Network Settings.
  3. Select Configure Network.
Legacy Xbox 360 Dashboard:
  1. From the Xbox 360 Dashboard, move to the System blade.
  3. Select Edit Settings.
IP settings, IP address, subnet mask, and gateway loadTOCNode(2, 'moreinformation'); Collapse this imageExpand this imagehow do i set up xbox live - networksettings-basic.jpg
After you select either Configure Network or Edit Settings, you will be on the Basic Settings tab, which contains your IP and DNS settings. When you select the IP Settings block, you are prompted to select an Automatic or Manual configuration. If you select Automatic, the Xbox 360 console will try to automatically determine your IP settings from your network or from your modem or Internet service provider (ISP). This option is recommended for most users.
You may have to or prefer to manually configure the IP settings, especially when a static IP address is used. This is necessary only if your ISP has issued a static IP address, or if you have configured the router to issue static IPs (and DHCP is not used). To manually configure the settings, select Manual, and then enter the IP Address, Subnet Mask, and Gateway by using the keyboard on the screen. When the information is complete, select Done.
DNS settings, primary and secondary DNS servers loadTOCNode(2, 'moreinformation'); After you select either Configure Network or Edit Settings, you will be on the Basic Settings tab, which contains your IP and DNS settings. When you select the DNS Settings block, you are prompted to select Automatic or Manual configuration. If you select Automatic, the Xbox 360 console will try to automatically determine your DNS settings from your network or from your modem or ISP. This option is recommended for most users.
You may have to or prefer to manually configure the DNS settings, especially in scenarios in which a static IP address is used or where DHCP is not available or not offered by the ISP. To manually configure the settings, select Manual, and then enter the primary and secondary DNS server names by using the keyboard on the screen. When the information is complete, select Done. Note You do not have to enter a secondary DNS server to connect to Xbox LIVE. A secondary DNS server is required only if the primary DNS server has technical problems.
Wireless settings loadTOCNode(2, 'moreinformation'); To configure your Xbox 360 console to connect to your wireless network by using an Xbox 360 Wireless Adapter, follow these steps:
  1. Access Network Settings .
  2. On the Basic Settings tab, select Wireless Settings.
    Note If the wireless settings area does not appear or is unavailable, click the following article number to view the article in the Microsoft Knowledge Base: 909333 (http://support.microsoft.com/kb/909333/ ) While attempting to view the settings for a wireless network connection, all the wireless functions appear to be disabled in the Xbox Dashboard
  3. Follow the instructions to select your wireless network, select your wireless network name, and then enter your wireless security information.
  4. Select Done.
PPPoE settings loadTOCNode(2, 'moreinformation'); If your Internet service provider uses PPPoE authentication, you have to enter the settings in the Xbox Dashboard if you have a direct connection through a modem. If you use a router or a gateway instead, leave the PPPoE settings blank because the router performs PPPoE authentication. Note If your ISP does not use PPPoE authentication, make sure that these settings are blank. To learn whether your ISP uses PPPoE authentication and to learn the correct PPPoE information, contact your ISP.To configure the PPPoE settings on your Xbox 360 console, follow the steps for the version of the Xbox Dashboard that you are using.
New Xbox Experience (NXE) Dashboard:
  1. Move to the System area of the Xbox Dashboard by using one of these methods:
    • Press the Xbox Guide button on your controller to open the Xbox Guide, scroll to the right to access Settings, and then select System Settings from the list of options.
    • Select the My Xbox channel, and then scroll to the right to select System Settings.
  4. On the Additional Settings tab, select PPPoE Settings.
  5. Use the keyboard on the screen to enter the PPPoE information that was provided by your ISP.
  6. Select Done.
  7. Select Back to return to the main Network Settings area.
  8. Select Test Xbox LIVE Connection to restart the test with the new PPPoE settings that you have configured.
sure it will work thank you
Posted on Mar 21, 2010
Activat my xbox360
Set up your Xbox 360 or Xbox 360 S console - Xbox.com
https://support.xbox.com/xbox-360/system/console-setup
XboxSetting up your new Xbox 360 console is easy. Follow these step-by-step instructions to set up your Xbox 360.
Set Up and Use the Netflix App on Xbox 360 - Xbox.com
https://support.xbox.com/xbox-360/apps/netflix-setup
XboxLearn how to set up and use the Netflix app on your Xbox 360 console. ... and install the app. To start the Netflix app later, go to apps, My Apps, and then Netflix.
Dec 28, 2015 | Microsoft Xbox 360 Elite Console
Tip
Xbox Live: How to set up Xbox Live
Xbox 360: Setting up Xbox Live
To setup Xbox Live on your Xbox 360, follow the steps shown below:
1. Get access to High-Speed Internet Service (DSL or Cable): Xbox Live Compatible ISPs
2. Connect to your home network, for instructions, visit: Home Networking
3. Once you are connected to Xbox Live follow these steps to create your profile from your console:
  • In the Xbox Live section, select Join Xbox Live, and then press the A button.
  • Press the A button again.
  • Follow the directions on the screen.
  • Select a membership (only a Gold account will allow you to play other gamers)
  • Tips for creating a new profile:
    - When creating a Windows Live ID, use an email address that you commonly use
    - Record your email address, gamertag and password for future reference
    - You can only associate one email address with one Windows Live ID
    on Sep 30, 2008 | Microsoft Xbox 360 Console
    Paid a years on xbox360 gold membership for my son, xbox is connected to live. I am connected for first month free but my son can not get connected.
    Your son's xbox live account might have no permission to access online xbox gaming, to be able to check and correct this problem try following this steps:
    1. Go to My Xbox and open System Settings.
    2. Select Family Settings, Xbox LIVE Controls.
    3. Sign in using the e-mail address and password you used when you set up your child's Xbox LIVE account.
    4. Select Online Gameplay, Xbox 360 Online Games.
    5. Select Allowed or Blocked
    Jun 10, 2010 | EA Sports Video Game Consoles & Games
    My xbox 360 wont connect to xbox live and ive tried everthing
    things you can do..... first start by connecting your 360 to the router and run a test through the system setting menu on your 360 dash board.... to do this go to system setting menu and select the network setting menu.... after selecting network setting there should be an option to test you`xbox live connection.... this is the first step in trouble shooting.... if your xbox connects to the network or router than the problem may be in the Internet connection.... after you have a connection between the xbox and the router... connect the router to the Internet and run the the test again... if you are connected to the network and the internet but still not to xbox live try doing a system update to update your system with xbox live.... after doing all of these steps you may have purchased and xbox that has been banned from xbox live and will not be able to join xbox live..... a more simple solution is that you may not have an xbox live account and simply need to set one up... this can be done through the xbox or you can go to www.xbox.com and set up a live account... you can also find FAQ's and trouble shooting steps there
    Apr 22, 2010 | Microsoft Xbox 360 Console
    Password on famliy setting for xbox live preowed console
    From the XBox website:
    Managing Xbox LIVE Activity
    Xbox LIVE Controls come into play only when you take Xbox 360 online, and they're linked to a child's profile and gamertag. When an Xbox LIVE account is created, the service asks for the member’s age to determine whether to apply Family Settings to that account.
    Parents are also required to create or use an existing Windows Live ID. The Windows Live ID is associated with the child’s Xbox LIVE account and protects the settings from being changed later by the child. To change a child’s settings, first select the child’s account name and connect to Xbox LIVE. Once signed in, enter your Windows Live ID password to unlock the settings.
    To see these controls, go to My Xbox, open System Settings, then selectFamily Settings, Xbox LIVE Controls.
    Aug 25, 2009 | Microsoft Xbox 360 Console
    Trying to get xbox live
    You have to purchase an xbox live membership, and then you can connect with an ethernet cord right to the consel from your modem, or purchase the wireless adapter for it.
    Jan 27, 2009 | Microsoft Xbox 360 Console
    Can't connect to Xbox Live
    mtu is not working cant hook up xbox live
    Nov 25, 2008 | Microsoft Xbox 360 Console
    My xbox 360 says its connected to the internet, but it wont sign in on xbox live
    To troubleshoot your Xbox Live connection from the Xbox Dashboard:
    1. Go to the System area of the Xbox Dashboard.
    3. Select Test Xbox Live Connection.
    4. After the system has completed its tests, select More Info to learn more about your network, paying close attention to any test that failed.
      In each case, the More Info section will offer tips for correcting the conditions preventing you from accessing Xbox Live.
    5. Select Edit Settings to adjust your:
      • IP Settings (including IP address, subnet mask, and gateway)
      • DNS Settings (including primary and secondary DNS servers)
      • PPPoE Settings (including user name, password, and service name)
      • Advanced Settings (including host name and altern
    Oct 01, 2008 | Video Game Consoles & Games
    XBOX LIVE
    u may need to adjust your modem/router settings check this link out
    http://www.jlsnet.co.uk/index.php?page=cc_xbox
    Feb 15, 2008 | Microsoft Xbox 360 Console
    Get go to xbox live
    For some reason everyone has the same problem buy the Xbox 360 wireless kit and should work but for now you might as well just wait untill get its fixed
    Dec 30, 2007 | Microsoft Xbox 360 Console
    Microsoft Xbox 360 Elite Console - Black Logo
    286 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    Ekse
    James Bradburn
    James Bradburn
    Lee Hodgson
    Lee Hodgson
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
