LG Shine KE970 Cellular Phone Logo
Posted on Feb 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix or replace the charger port on the phone
Anonymous
Level 2:
  • Expert 49 Answers
  • Posted on Feb 11, 2010
Anonymous
Expert
Level 2:
Answers
49
Questions
0
Helped
27273
Points
279
We offer a charging port replacement service for LG phones for $45.
We guarantee that we can fix your phone or we do not charge you anything. We also warrantee all of our repairs for 90 days and we offer free return shipping.
Please call us if you are interested.
Spring Mobile Service and Repair 720-274-2492
555 Broadway Denver CO 80203
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
539
Points
How to fix a sony ericsson charging port for a w760i
1helpful
I have a Samsung.galaxy note 1. It doesn't recognise the charger. I have had the charger port fixed and bought a new battery and a new charger. It still won't work I really like this phone but.replacements...
when you plug in the micro usb does the computer see the phone? If it doesn't you still have a problem with the port and who ever "fixed" it didn't fix it..
Oct 16, 2014 • Cell Phones
When I try to use my car charger for my sciphone, after about 45 seconds it always says "Warning, Bad Contact Charger!" What does this mean and how do I fix it???
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
My battery wont charge on my motorola rival i bought a new battery and it still wont charge.
If your phone does not seem to charge. It is as a result of either the charger or the charging port.
To test if it is the charger;
Try to use a tested okay charger on your phone.
Try your charger on another phone to see if it would charge the phone.
If it does not work,then it is the charger.
All you have to do is to replace the charger.
Test if it is the charging port;
Try to use a tested okay charger on your phone,
If it does not charge the phone,
Then it is the charging port that has a fault.
To fix the charging port;
  1. get the appropriate screwdriver,
  2. remove the back cover, the battery and the sim,
  3. Then you will remove the stickers, you will find some screws at the angles of the phone, unscrew them,
  4. Run an object like a credit card around the line across the phone and apply a little force to separate the stainless part of the phone,
  5. You will have access to the panel of the phone,
  6. Try to locate the charging port of the phone,
  7. Disconnect it and replace it with the new you got for it,
  8. Reverse the process to reassemble the phone.
Take care
Jun 21, 2010 • Cell Phones
2answers
My casio boulder will not charge how do I fix it
Hi, you can check with another charger first to know exactly what the problem really is before you can take the next step .Also check the phone on another charger.
After checking with another charger, if charger work,that means the charging sport where you plug in the charger is not working and need to be replaced.
If when you check the charger with another phone and and the charger doesn't work, replace charger.
Take care.
Charging no respance
Hi, problem can be solved. When charging a phone and it does not respond,it means that either the charger or the charging port where you fix your charger in is faulty.
First you can try and use another charger to check if phone will charge. If it charges, that means the charger needs to be replaced,but if not charging,charging port will need to be replaced .
Take care.
3helpful
2answers
I have a samsung rant and the charger port that is connected to the charger wont charger. How do i fix it?
there are 2 possible reasons for the problem u mentioned..
  • either ur phone charger port or its internal connection is defected
  • or ur charger circuit or wire orits pin is the problem
you can find it by connecting ur phone with system using usb data cable..if it charges then ur charger kit is to replaced..else u must service ur phone
1helpful
Blackberry curve 8310. My charger port will not charge I can see one of the conectors looks like it got bent and am not able to correct it is this replaceable? Where can I get it repaired at a low cost?
Your problem is the charge port on your phone needs replacement. We fix them through our ebay repair listings for $38.95. Just type "blackberry charge port repair" for your ebay search and look for the listings with "PORT REPAIR" around a charge port in big red writing. Our ebay username is "its-a-pheo" We have fixed hundreds of them and complete the fix the day we receive the phone from you. Feel free to email me with any questions at all... [email protected]
I have a nokia that has stopped charging how do i fix it?
replace it. unless another charger works, your charge port is damaged. this is not warranted, but insurance covers it as damage if you bought the insurance. if the other charger works- cheers~! And throw out the old one, if you must replace the phone, NEVER use the old chargers from a phone that has had port damage!
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
