Washing machine my lg washing machine is noisy and shakes voilently during the rinse and spin cycle,so pls give me solution , thank u. my model no WF-N7069NN top load
Question 2 also edited for clarity, 'LG' not 'lg'.
No model details again.
Surely not during 'Rinse' cycle? That just adds water and gently tumbles to get the soap out and complete the washing by further agitating the clothes. You must mean during spinning and much depends on if it is a front loader, or a top loader. For both, machine not level front to back and left to right and / or not sitting firmly on all 4 feet.
Top loader, bulky load unevenly loaded.
Front loader, single bulky item causing an uneven load.
The drum is controlled by a breaking system at the bottom of it. It is the agitator in the center that does most of the work during wash and rinse. The drum would spin very fast during spin cycle.
Check if the solenoid for brake control is working. Check that the drive belt is not sagged. It should be tensioned correctly.
it appears the motor's sensors could be going bad on it so the diagnostic computer doesnt know what to do but spin the motor in a spin cycle contact LG for a replacement motor for this washer
Possible that the inlet flow is low , check the inlet valve and filter. Also try using the manual settings and if all the cycle works well then it is possible that the fault is with the controller unit or a possible errors from the level controller or the inlet valve. It is best to remove them , check reset after cleaning.
Check the Vibration damper rods to be sure that... 1. They are there and mount is solid. 2. If they are broken in 1/2. 3. The plastic knuckle mounts are not missing/broken. 4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sounds like the switch which cuts the machine off when the load is unbalanced. My guess is that:
This switch is being triggered too easily
The springs holding the bowl up are either stretched or one is broken;
The machine may not be level.
