No agitation or spin? try these:
WATER PRESSURE SWITCH: This switch keeps your washer from overflowing. It is responsible for shutting off the power to the fill valve and redirects the power to the timer to start the washing machine running once the correct water level has been reached. Meter check
ur water pressure switch?
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash starts - then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well.
Or take the original hose tube and plug one end and blow into it AT the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ?
Sometimes they get busted open or a pin hole and release air causing the water switch diaphragm to not open.
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS. However in G.E models the cam dogs are replaced with what is called an agitator coupler. (located at bottom of tub)
Remember to check the agitator spline as well for worn broken teeth.
By the way my advice is free cuz God is good!
Washer will not drain:
The
drain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure to
check the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "
Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Read more:
http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
The washing machinedrain hoseis where the water flows through to get the water out.
If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it
The
water pump belt(to drain out the water) may have broke or become frayed or loose.
If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing the
NO DRAINissue and remove and replace if needed.
If the
lid switchis not working as required it will cause your washer to not drain (and many other problems).
This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuity
My advice is free cuz God is good!
Fix Washing Machine That Won Drain Washer Not Draining Water
