Question about CorningWare SC60 Slow Cooker
Slow cooker will only stay on warm. How do I put
Slow cooker will only stay on warm. How do I put it on high?
Posted by sandramarieo on
  • charles May 11, 2010
    This slow cooker has three settings: LOW, HIGH and WARM..... When
    your corningware slow cooker is initially plugged into a wall outlet,
    the display will show "0". This display indicates the programmed number
    of hours for which a meal will cook. The slow cooker can be programed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears. If
    1,2,3,4,5, or 6 hours are selected, then the slow cooker will operate
    on the high setting. If 7,8,9, or 10 hours are selected then the slow
    cooker will operate on the low setting. To start the cooking cycle
    press the ON/OFF button. To interrupt the cooking cycle at anytime,
    press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the warm setting.
charles
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 97 Answers
This slow cooker has 3 settings LOW, HIGH, & WARM
When you plug the slow cooker in the display should show a "0". When you press the "COOK TIME" button, the display should go to 1 then 2 then 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the "HIGH" setting. If 7,8,9, or 10 hours are selected, then the slow cooker will operate on the "LOW" setting. To start the cooking cycle press the "ON/OFF" button. To interrupt the cooking cycle at any time, press the "ON/OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the "WARM" setting. If the "ON/OFF" button is pressed when the the digital display shows "0", then the slow cooker will automatically start on the "WARM" setting.
If the "COOK TIME" button does not change the display numbers then unplug the slow cooker and hold both buttons down as you plug the slow cooker in. Keep the buttons pressed for a count of ten, then release them and the slow cooker should work correctly
Posted on Mar 06, 2010
I pushed the cook time button but it still says zero what do I do
Hit the on/off button, so that the cooker looks like it is off, then hit the cook time button up the the number of hours you need to cook. This slow cooker has three settings: LOW, HIGH and WARM..... When your corningware slow cooker is initially plugged into a wall outlet, the display will show "0". This display indicates the programmed number of hours for which ameal will cook. The slow cooker can be programed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears. If 1,2,3,4,5, or 6 hours are selected, then the slow cooker will operate on the high setting. If 7,8,9, or 10 hours are selected then the slow cooker will operate on the low setting. To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the warm setting.
May 11, 2010
Nov 19, 2012 | CorningWare SC60 Slow Cooker
I need an owners manual for the SCVC651
I couldn't find the specific manual for this, but I did find some basic instructions on a personal review:
"Rival calls this a SmartPot and describes this unit as "programmable". All this really means is that you can program the slow cooker to cook either on "High" or "Low" for up to 20 hours, in 30 minute increments and then it will automatically switch to the "Keep Warm" setting and keep your meal warm for hours. You cannot program multiple steps, such as going from the "High" to the "Low" setting. The red, LCD clearly displays the remaining cook time.
Simply plug in the slow cooker, and then push the clearly marked buttons (with a pleasant, audible tone) to move from "Low" to "High" to "Keep warm" settings. Then push the Timer Button to set the desired cook time."
Hopefully, this helps answer your questions!
Nov 23, 2010 | Rival SCVC651-F Slow Cooker
HOW TO USE AUTO SETTING
It looks rather like my slow cooker which has a 3 position switch with LOW, HIGH and AUTO.
AUTO uses a thermostat control to prevent the contents from boiling. Useful if being left unwatched. HIGH setting can cause burning if contents not stirred, and LOW setting is only of use to keep things warm. Hope that helped.
Oct 05, 2010 | West Bend 84384 Slow Cooker
Heat settings on enheat slow cookers
Generally, the lowest number is the lowest temperature setting and the highest number is the hottest temperature setting
Jan 02, 2010 | CorningWare SC60 Slow Cooker
How do I start the cooker on low?
The manual says "When your corningware slow cooker is initially plugged into a wall outlet, the display will show"0". This display indicates the programmed number of hours for which a meal will cook.
The slow cooker can be programmed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears.
If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on HIGH setting. If 7,8,9 or 10 hours are selected, then the slow cooker will operate on the low setting.
To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
When the full cooking cycle is complete, your corningware slow cooker will automatically switch to the warm setting, to keep food at a warm serving temperature."
If, after you plug the slow cooker into the outlet, the COOK TIME button does not work, unplug the cooker, hold both ON/OFF and COOK TIME buttons down, plug into wall socket and wait till the display flashes. Release both buttons and the slow cooker buttons should both work.
Dec 18, 2009 | CorningWare SC60 Slow Cooker
Need a manual for the corningware sc60
The manual basically says... This slow cooker has 3 settings LOW, HIGH, and WARM. W hen you plug the slow cooker in the display shows "0". When you press the "COOK TIME" button, the display should go from 0 to 1 to 2 to 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the HIGH setting. If 7,8,9,or 10 hours are selected, the slow cooker will operate on the LOW setting. To start the cooking cycle, press the "ON/OFF" button. To interrupt the cooking cycle at any tim, press the "ON?OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the WARM setting. If the "ON/OFF" button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
If the "COOK TIME" button does not change the display numbers, unplug the slow cooker. Hold down both buttons and plug the slow cooker in and keep them pressed down for a count of 10. Release the buttons and the slow cooker should work now.
Nov 28, 2009 | CorningWare SC60 Slow Cooker
When you set the cook time it goes to warm will it change after it warms up
with this slow cooker it is automatic for temp settings you set the time and the rest is automatic, 1-6 ohurs starts on low and 7 and above start on high it worked out great
Nov 06, 2009 | CorningWare K4903 Slow Cooker
I had the exact same thing happen!
First some common sense, there is no such thing as partially defrosted - it's either frozen or it isn't as far as cooking safety. A slow cooker, even on high, only takes food to simmering temperature and holds it there, and it does it very slowly. Put something frozen inside and cover with glass, the glass gets very cold and then turn it on high and go away for several hours....unless the glass is Corning Ware and rated for freezer to oven, expect it to break one out of ten times. Also, putting frozen food in a slow cooker and thawing while slow cooking gives you a good chance at growing some unhealthy bacteria in the cooker as the meat warms. Meat should always be thawed fully before placing in one of these units, as the directions specify.
Sep 22, 2009 | West Bend 84356 6-Quart Slow Cooker
Can't change temperature-stays on "warm"
Push the COOK TIME button, if the time changes then if you leave the number of hours between 1 and 6, and press the ON/OFF button, it will cook on high that many hours. If you leave the number between 7 and 10, and press the ON/OFF button, it will cook on low that many hours. If you leave the number at "0" then the slow cooker will cook on WARM. If the COOK TIME button does not work, unplug the slow cooker, hold both the ON/OFF button and the COOK TIME buttons down and plug it into a wall socket. After the lights flash a few times, release the buttons. the switches should work.
May 19, 2009 | CorningWare SC60 Slow Cooker
CorningWare SC60 Slow Cooker Logo
2,281 people viewed this question
Top CorningWare Crock Pots & Slow Cookers Experts
gbob59
Marvin
Marvin
NOEL
NOEL
Are you a CorningWare Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
