Question about Eagle Fishmark 320 Portable Fishfinder
I am having trouble getting my Eagle Mark 320 to hold settings once the key is turned off. Can you assit me? I do not have a owners manual for it? Can you suggest where I could lacte an owners manual
Posted by cdpribyl on
Gene Pitts
    Scholar:
  • 159 Answers
For FREE owner's manuals visit 'www.eaglesonar.com'
Eagle Electronics
P.O.Box 669
Catoosa, OK 74015
Posted on Feb 12, 2010
Just purchased and Eagle Fishmark 320 used. Will not display depth reading - just shows 0'0"? I have reset to factory settings. We have had in lake,same thing. Right now in 5 gallon bucket of...
Hello! Do you have the PDF users guide for your unit? I'm looking at a copy in the troubleshooting section...I don't want to cover information you have already looked at or tried...Since I do not know if you have that manual I'll give you a few items to check...
Measure the battery at the units power connector...Must be at least 11 volts DC...In portable mode it uses 8 D cell batteries= 12 volts
Make certain the Transducer is securely connected...
Did you use the in-line fuse supplied with the unit?...
Try the Manual Depth Range...First turn off Auto Depth Range...From the sonar Page Hit MENU...Down-arrow to Auto Depth Range...Hit ENT...Hit Up-Arrow to Depth Range...Hit ENT..
And the Depth Scale Range appears...Up-Arrow or Down-Arrow to select a different depth range...Hit Exit...The minimum depth the unit can read is 5 feet...
If you do not have the PDF guide, here is the link...
http://www.eaglenav.com/upload/Eagle/Documents/Manuals/seafinder320df_0143-661_101602.pdf
Let me know how you make out....Guru....Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Sep 11, 2011 | Eagle Fishmark 320 Portable Fishfinder
We have a 1997 cadillac deville. installed a master window switch and left rear window motor. Technition reached inside vehicle and unlocked rear door lock by hand and set off alarm. we tried several times...
My wife had a car that to reset the problem we had at the time, the owners manual stated that in order to reset we had to turn on the key to the run position(do not start the car just turn key to run) next hit the brake pedal 3 times quickly and hold on the last push off the brake pedal, while holding down the pedal turn off the key. Release the pedal then turn the key back to the run position and this may fix your problem. Check your owners manual. Your car procedure may differ.
Jan 26, 2011 | 1998 Cadillac DeVille
Need a manual
try going to eagles web site and download a manual to your printer. good luck.
May 29, 2010 | Eagle Fish Elite 480 Skimmer Transducer...
My Eagle will no longer read the bottom beyond 50 ft, even with the boat stopped and the outboard turned off. The voltage is listed at 12.1 volts; there are no kinks or cuts in the trasnducer cable.
It seems most likely that your manual range has accidentally been set for 50' or less. Go into the menu and set to auto range. Here are the exact keystrokes as shown on PAGE 51 of your manual:
MENU> scroll down to DEPTH RANGE> ENTER> Exit
If this doesn't work, try doing a ful reset, as shown on PAGE 64 of your manual:
MANU> MENU> scroll down to RESET OPTIONS> <- to YES> ENTER
The Fishmark 320 is an excellent unit, and it works great in full-auto mode if you have the transducer mounted properly. Let us know if this doesn't fix your problem.
Dec 13, 2009 | Eagle Fishmark 320 Portable Fishfinder
Manuals
http://www.retrevo.com/s/Eagle-320-GPS-review-manual/id/517bh945/t/1-2/
Hit the Icon "GET MANUAL"
Nov 01, 2008 | Eagle FishElite 320 GPS Receiver
Depth dosnt work on egle fish mark 320
MY depth finder blinks 0.0 depth all the time
May 11, 2008 | Eagle FishElite 320 GPS Receiver
Eagle Fishmark 320 Portable Fishfinder Logo
255 people viewed this question
Top Eagle Boating Experts
Michael Thomas
Michael Thomas
Mike
ray gallant
Are you an Eagle Boating Expert? Answer questions, earn points and help others
