Question about Sony Playstation 3 (PS3) Console
PS3 wont display video or audio
I was playing my PS3 yesterday when the power went out all of a sudden for like 5 seconds. Everything turned back on except the PS3's video and audio components. The PS3 seems to be on but when i try to turn it off using the power button, it beeps 3 times. I keep trying to turn it off but it wont let me, just keeps making the 3 beeping noises. The only way to shut it off is to unplug the power cable. I've tried to unplug the HDMI cable from both the PS3 and tv, but still no luck. I have a 120 GB PS3 slim.
Posted by thissux18 on
Anonymous
    New Friend:
    Problem Solver:
  • 15 Answers
This is a rare problem ............ i faced similar kind of problem
i solved my problem with the help this repair guide you can also try this out i hope this will help you a lot .......
all the best
Click Here
Posted on Jul 26, 2010
1 Related Answer
Anonymous
  • 8 Answers
SOURCE: My PS3 slim, 120 gb drive freezes periodically, has yellow flash
yes its the cd drive....if it's under waranty still then you can call them and fix for free......or they run you though some test.......if it is out of waranty then you will pay aabout 50 bucks to repair it....i know mine did the same
Posted on Apr 17, 2010
Hi, I bought a brand new ps3 console yesterday and everything worked fine when I set it up. I did not have to change any settings in relation to the display at all and it was perfect when I tried out my...
Hi.
No you shouldn't need a new TV, all you need to do is reset the video settings, follow the guide below >>>>>
  1. Make sure that you have only 1 type of video cable connected between your PS3 and your TV or monitor, an HDMI cable is optimal. If you have multiple video connections the reset sometimes does not work.
  2. Make sure that your TV or monitor is turned on and set to the proper input for your PS3.
  3. With your PS3 in standby mode, turn your console on using the front power button and hold the button down.With the button held down, You will here one beep when the console first turns on, and, after about 4-5 seconds, you will here a second beep. When you here the second beep let go of the button.
  4. If you watch the screen you should see it flicker once or twice and then your system should boot up and go to a screen to confirm your video settings. Simply confirm the settings and you should be able to resume playing your PS3 as normal.
  5. If your system does not boot up and give you the confirmation screen for your video settings, then you should shut the system off and restart the system as normal. This will usually finalize the reset of the video settings.
  6. If your system still is not displaying video then please repeat steps 1-5 again. It is unlikely but, you may have to reset the video 3-4 times before it works with your console. The reason for this is unknown.
  7. The procedure to reset video ,on your PS3, should be complete at this point and you should be back up and running as normal.
NOTES: PS3 "slim" models are always in standby mode when plugged in. PS3 "fat" models must have the rear power switch turned on. If you are only using the composite video cables, then there will be no confirmation screens for your video settings.
Regards.
Jan 01, 2013 | Video Game Consoles & Games
Had the ps3 working fine, plugged it into another tv and nothing, the tv wont pick up the signal.. went to plug it back into the 1st tv and still nothing
Try resetting the display back to standard definition -
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later. Let go of the power button when you hear this second beep
Wait for the PS3 display to reset
Hope this helps
Oct 26, 2010 | Sony Playstation 3 (PS3) Console
Playstation not registering with hdmi or video mode suddenly
Please try the following steps :-
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep once when you press it, then once more 5 seconds later. Let go of the power button when you hear this second beep.
Step 3. Wait for the PS3 to reset display settings back to standard.
Hope this helps
Nov 05, 2009 | Sony Playstation 3 (PS3) Console
Ps3 plays audio but does not show image on tv
Well you can just use the hdmi cable if you're going both audio and video in to your tv. With your hdmi cable you get the best quality for both.
But in anycase, it seems that your PS3 is set up to output video via HDMI cable. To reset our video output settings, simply power down your PS3 (turned off) and hold down the power button until you hear the second beep. (around 5-10 secs) Power back up and hopefully you'll have video via your av cable. Hope this helps.
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
PS3 Problem... I turned on my ps3 but nothing shows up on the television screen and controls wont even detect... PS3 shows that it is receiving power because the power light on ps3 is green. Can someone...
Turn the power off on the switch on the back, and then back on again. Hold down the power button, keep on holding it down after the first beep, but let go once another couple of beeps sound. It should then take at max a minute but then it should show a screen set up section.
Apr 09, 2009 | Sony Playstation 3 (PS3) Console
My ps3 will turn on but will not transfer audio/video to my tv.
Bill...
Try flipping the switch in the back of the PS3 off and then on so the light on the front is red... Then, hold down the power button on the front of the PS3 for about 5 seconds until you hear a "beep"... This should reset the audio/video, and you'll be able to see and hear everything... Just did it myself!!!
Allen
Apr 06, 2009 | Sony Playstation 3 (PS3) Console
PS3 won't start
u have to wait for about 30 mins before turning it back on
coz when it does that it's tired
hope this helps
Sep 19, 2008 | Sony Playstation 3 (PS3) Console
PS3 NO VIDEO/AUDIO output- no display NOTHING NEED HELP!!!!!!!!
I have a friend at playstation and when I called I had no video or audio using the AV Multi Out.
The soultion is:
1. Turn Off in back (wait few seconds for it to re-set)
2. Turn on in back
3. Turn on in front and hold your finger on it 'till it turns off again -
(you get the beep on then the three beeps for reset and it will eventually beep again and turn off)
4. Turn off in back (wait few seconds for it to re-set)
5. Turn on in back
6. Turn on in front hold finger for three beeps and damn it works!
I was so Pissed for two days and spent $80.00 on new cables (that I did not need) and the answer was so simple.. The SONY on-line troubleshooting instructions really need to be updated!
Let me know if this works for you!
Thanks
Mike M
Jun 19, 2008 | Sony Playstation 3 (PS3) Console
Ps2
hold down the power button untill it beeps twice. about 3 seconds which should restart the settings to the default composite settings. from there you can change the settings back to hdmi or whatever you had them at before.
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
Not powering on
1. The power cord is not completely insered. 2. the impedance selector switch on the rear panel is not fully set to the upper or lower end - (set it when the unit is in the standby mode) other then that, you will have to call for a service.
Nov 26, 2005 | Yamaha HTR-5150
Sony Playstation 3 (PS3) Console Logo
153 people viewed this question
Top Sony Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
