question does not adequately describe problem but b4 you do anything else verify that the doors are not being held open by contact between the door and a shelf.
Then verify that the target temp is set correctly.
Fix All My Computer Shortcut Links
Computers often use shortcut links to make it easier for
users to locate and open files.
These links are commonly placed in a folder easily
accessible to users, such as a desktop folder.
When a shortcut is created, it is given directory
information and an icon.
If the file associated with a shortcut is later moved, the
shortcut may fail to locate the file.
When this problem occurs, you need to update the shortcut's
directory information.
This process is often automated by operating systems, but in
a some instances, you need to repair shortcuts manually
Right-click on a broken shortcut link's icon.
Select the "Properties" option. Locate the
"Target" box and copy its information into your clipboard using the
Ctrl and C keys.
Open the "My Computer" folder on your computer and
paste the target information into the folder's address bar using the Ctrl and V
keys.
If the address bar is not viewable, you may need to enable
it in the folder's settings.
Find address bar options in the "View" menu under
"Toolbars."
The file's target path folder will open.
Locate the file in the target path folder.
If the file is not present, the target path is inaccurate
and likely the cause of the shortcut link error.
Locate the file in its correct folder.
Browse folders or search for the file by typing the file
name into the "Start" menu.
After finding the file, open the properties of the shortcut
link icon again.
Copy the file's correct path, from the containing folder's
address bar, and paste it in to the "Target" box, replacing the
incorrect link.
Another way to find a file's target path is by right
clicking on the file and selecting Properties.
You can find accurate target information in the
"Target" box, provided the icon is the original file icon and not a
shortcut.
Ctrl and C keys.
and paste the target information into the folder's address bar using the Ctrl
and V keys.
"Toolbars."
link icon again.
incorrect link.
shortcut.
Freezing can be from many reasons. I can sort of list a few common ones that I have run across with duplicators.
o Defective drive in the drive chain (very common). o Power supply is having a slight failure or instability. o Connector in the system having poor contact (not very common) o Fault condition in the controller, and or the mother board. o Corruption in the firmware (operating program in the mother board).
It sounds like your video card isn't powerful enough for the game (I would suspect). Re-post your system specs and what game you are trying to play and someone can look specifically at your system vs. the game requirements.
Go To Web. Click on Live Search. Say any business or service name, Target, Walmart, Pizza, Mcdonalds, etc. Click on one of the finds. When the address pops up, click on the little car icon. Then it takes you to GPS. From now on GPS works.
this problem may be related to the magazine . try another one and see if it still happens. The nagazine spring may be too weak to get the last round up high enough to feed into the chamber before the slide comes ahead
no solution...the unit is junk!
I've had one for about 6 months, played about 6 DVD's, and now it won't do anything at all! neither the button son the unit nor the remote will power it up. it won't do anything except open the lid.
01) Press and hold down the "Calendar" and "iPAQ Wireless" buttons.
02) While holding down these buttons, use the stylus to lightly press the "Reset" button/hole on the back of the iPAQ until the screen goes blank.
03) Release the "Calendar" and "iPAQ Wireless" buttons.
04) Press the "Reset" button/hole again (so that it resets/powers on.)
