Try cleaning all the vents inside the dryer all the way to the outside. Be sure and clean around the blower wheel lots of things get in where the blower is pencils nails everything. They will block the wheel so it can't turn. Also vacuum the lint out of the motor. Lint most likely the problem. Hope this helps.
Check the motor capacitor,sometimes the capacitor could be faulty or the motor is faulty or check if the motor is receiving power,if it's receiving power try to replace the capacitor if the is any in the system,if still it's not working then the motor could be burnt.
Most likely, the operating thermostat has failed, and the high limit thermostat turns off the dryer when it gets too hot. When it cools down, it will start again.
If the heating element is getting very hot that means there is no air flow across it. If the drum doesn't turn then the blower is not turning causing the element to get very hot. Could be drum belt, drum rollers, or motor.
It may be the element has gone bad. You can visibly check it to see if it is bad. Quite simply the wire will be burned in two. I assume your drum is turning o.k.
yes very possible timer but my guess on the times i seen the problem would be the heating element are the thermo fuse on the elemnt canister when the heater does not come on the timer will not move ck the heater and the fuses on the heater canister it will fix your problem
