there should be a spare thread holder on the machine and a bobbin mount near the drive wheel of the machine. The bobbin goes on the bobbin mount which is pushed onto the drive wheel in order that it is rotated. the thread should be wound onto the bobbin and the the motor should be actuated. This should wind the bobbin. This is usually done with the thread out of the needle.
You are not exactly threading the machine when you wind the bobbin. So follow the directions for winding the bobbin, make sure the thread fits under the little revolving wheel, and make sure that the stitch part of the machine is disengaged.
Check to see that all of the thread is out from under and around the bobbin. You may have to take the thing off that the bobbin fits into. Sometimes lint and excess thread pieces will build up under there. Did you check to make sure the wheel that you turn when you wind the bobbin is snug?
is clutch disengaged? inner wheel in flywheel, hold flywheel and turn inner knob towards you to loosen. put bobbin on spindle and move to right to wind. if youve done this already and no joy then bobbin winder tyre may have perished. try www.sewingpartsonline.com to buy new one
most machines will have a rubber o ring as part of the bobbin winding mechanism, when you engage the bobbin winder, this o-ring will move over against the main engine drive wheel and this then makes the bobbin spindle turn. So yes, you may need to replace the rubber o-ring, they can perish and wear. Called Bobbin Winder Tyre, you could try www.sewingpartsonline.com, they have loads of Kenmore models listed but can't see yours. However, if you email them, they should be able to advise what part number it is. If you start by opening up the machine case and take a look at the bobbin winder area first, you may find this rubber has split or perished.
To wind a bobbin, reel on top of the machine, take the thread to the left and go around the small wheel, back to the winder, bobbin on the windere and wind the thread round a few times, slacken the stop motion and wind the bobbin.
If you have a drop in bobbin, hold the bobbin in your left hand, thread on the bottom of the spool, drop the spool in, take the thread through the slot to the left and lay it across the bobbin with enough thread to be pulled through by the needle
Cotton reel on top, take the thread from the reel to the left and over the top guide, straight down throught the tension discs, back up to the take up lever making sure the lever is at the top, through the lever right to left, straight down through any guides and thread needle front to back.
To wind the bobbin, reel of cotton on top, bobbin on bobbin winder making sure it is pushed to the left, take the thread to the left and round the small wheel and back to the winder, wind the thread round a few times on the bobbin, push the windewr to the right, and loosen the stop motion in the balance wheel.
The reason is probably because the winder post is not perfectly vertical, check that and also make sure you put the thread round the pretension wheel before you wind a bobbin, getting to the inside to adjust it is very difficult.
To wind a bobbin put the cotton reel on the top pin, take the thread to the left and round the little wheel and back to the bobbin that should be on the winder, wind the thread round a few times to take a grip, release the stop motion in the balance wheel, turn the winder button so the winder moves to the balance wheel and press on the foot control slowly.
When you put the bobbin in the bobbin case make sure it turns anti clockwise.
