Question about Dell Dimension 2400 PC Desktop
Dial up connection ok but wireless will not open explorer Dell computer 2000XP Eircom connection
  • Anonymous Feb 12, 2010
    Hello Mike
    When I use the phone connection the computer opens web pages as normal but when I change to the wireless connection a message appears cannot find server.
    The status of the wireless network is fine showing that it is connected and the signal is 100%
  • Anonymous May 11, 2010
    Can you please elaborate on the issue please. Clarification appreciated.
Anonymous
    Scholar:
  • 103 Answers
The dial up connection may be corrupt
delete the dial all the existing dial up connections from
internet explorer>Tools>internet options>Connections>
remove existing dial connections in Dial up and virtual private network settings
add a new dial up conection and set it up again
It show be up and running
Posted on Feb 24, 2010
Im on a dell dimension 3200c desktop,which is connected to an eircom wireless router which is connected to a landline... i would like to connect another pc using the signal from this.. i have a netgear...
first install the software that came with your wireless adapter after youve done that insert the adapter. open the network program have it seach for wireless signal if your router is useing wep enter the password click on conect you should be in
Feb 20, 2010 | Dell Dimension 3100 PC Desktop
How do i connect another pc to this one?i have an irish eircom wireless router....
You really didn't tell us enough to help, but I can offer suggestions:
If both computers have wireless adapters, all you have to do is to to the networking menu item (varies depending on the operating system which you failed to mention) and make sure you are on the same workgroup on both machines. You should then be able to see each other. You will, however, need to go into Windows Explorer and right-click on the folders you wish to share and enable sharing.
If you don't have wireless capability on the computers, they will have to be connected to the router with cable.
The whole subject of networking is really too large to address here. Guess I need to write a tip on it.
Router dell 2350 not detect by computer
open a explorer session go to tools/ internet options/connections/lan settings check off Automatically detect settings click ok, ok close explorer then open a new session and see if you get internet.
Oct 17, 2009 | Dell Wireless 2350 Router
Internet explorer won't open
when it says connected it means to the router, open up internet explorer>tools>internet options>connections tab and tick never dial a connection, or if it's already greyed out it's ok.
Assuming you have run the wireless network connection wizard first to set up the connection, if not it's in network connections and select new wireless connection or set up a wireless network.
Sep 24, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Trouble connecting wireless
first thing to do is to dissable the ethernet connection in network connections on your notebook so as the ip address does not conflict.
assuming it's XP and assuming DHCP is enabled in the router settings, right click on your wireless conection in network connections, properties>TCP/IP line, highlight it and then click properties again, then ensure obtain an ip address automatically is ticked, apply and ok, close window.
If neccasary run the wireless network wizard in new connections in network connections.
Open internet explorer>tools>internet options>connections tab and ensure that 'never dial a connection' is ticked, ok and close IE.
Open IE and click refresh a few times.
Sep 02, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cannot connect to internet via Actiontec M1000 (Qwest)
open internet explorer, go to tools, internet options, then the connections tab and make sure ' never dial a connection' is ticked, assuming you had a dial up connection before using the router, other than that you need to check the routers settings, like the password /username for your ISP connection and assuming you originally set it up using an RJ45 lan cable (supplied) before using the wireless.
Aug 23, 2008 | Dell Wireless 2350 Router
Trying to connect between cable pc xp edition and new dell vista laptop
the SSID is only the name which your connection is called.
If you have security enabled, you will need to type in the passkey when asked.
First go to internet explorer open it and go to tools>connections tab, then tick 'never dial a connection' and close I. Explorer.
go to control panel>network connections>right click on your wireless connection icon, then go to the TCP/IP line, highlight it, click properties, then select 'Obtain IP address automatically.
Select Ok, then close window, go to internet explorer, then open it up and you may need to click refresh a few times ,but should connect
Aug 19, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cannot connect to the internet
open internet explorer, go to tools, internet options, then the connections tab and make sure ' never dial a connection' is ticked, assuming you had a dial up connection before using the router on this pc or if you briefly used it.
Aug 18, 2008 | Dell Wireless 2350 Router
How can i unlock my router?
Firstly... avoid showing your SSID (eircom-123456789) here, as the WEP key can be reverse engineered from the SSID.
To change your SSID, connect your router to your PC with an ethernet cable, go to your web browser (Intenet Explorer, Forefox, etc) and type 192.168.1.254, and press return.
This will open the control panel for the router.
Select 'EXPERT MODE' from the menu on the right, and accept the warning prompt. Then click on 'CONNECTION' and the 'WIRELESS' on the menu on the right.
In the main window you can then change the SSID for your network.
You can also change some of the other options in this window such as enabling closed mode, change security protocol, password, etc.
Feb 13, 2008 | Netopia 2247NWG-VGx Wireless Router...
How can i unlock netopia 2247NWG
Feb 10, 2008 | Netopia 2247NWG-VGx Wireless Router...
Dell Dimension 2400 PC Desktop Logo
251 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
