Question about Lands Phones
I lost my manual book for beetel jade landline phone i want to Off the ''secret on'' option in the instrument , so that it can display the date and time and caller id , pls help
Posted by roopa_1231 on
Anonymous
    New Friend:
How to store any ext no. in quick dialing key
Posted on Apr 30, 2010
Where can I get User Manual for my Beetel X78 cordless landline combo
Have you tried google. The first thing to try is the manufacturers web site. If that doesn't work, there are lots of places that provide free downloads of manuals. Give this try first and see if you can find anything.
Sep 02, 2018 | Lands Phones
Tip
Checking Software Version
To check the phones software revision for Nokia Mobile.
On the main screen type *#0000#
To enter in the secret menu in Nokia Phone.
On the main screen type *#92702689# [*#war0anty#]
It will take you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
on Apr 02, 2010 | Cell Phones
Tip
Nokia_Mobile_Secret_Codes
*#06# IMEI
*#0000# view Software Version
*#746025625# [*#sim0clock#]
*#92702689# [*#war0anty#] secret menu:
2. Displays the Month and Year of Manufacture (0997)
4. Displays the date of last repairment - if found (0000)
5. Makes you capebel of transferring user data
6. Shows how many hours the phone has been on
*3370# Enhanced Full Rate Codec (EFR) activation
#3370# Enhanced Full Rate Codec (EFR) deactivation
*4370# Half Rate Codec activation
#4370# Half Rate Codec deactivation
xx# - xx position in Phone Book
NOKIA 9000
*#06# IMEI
*#682371158412125# soft version
*#3283# prod. date
NOKIA 7650
*#7979# phone reset
*#7470# hard reset
*#7370# master reset (like new phone)
on Apr 26, 2008 | Nokia N70 Cellular Phone
I forget my nokia5253 code plz what can i do unlock code
HI PZL TRY THE FOLLOWING THERE ARE THE LIST OF NOKIA
SECRET CODES .. >>
*#7780# Restores Factory
Settings (Memory, language,
counters are not included)
Nokia 3110 Secret Codes
*#746025625# [*#sim0clock#] : Checks if the
SIM clock can be stopped. SIM
clock stop is a kind of stand-by
mode which will save battery
time. This code doesn't work
with software version 4.59. Nokia 3110 Secret Codes
*#3110# : Checking the
phone's software (SW) - Also
called "Firmware Revision
Information".
Nokia 3110 Secret Codes *#92702689# [*#war0anty#]
Press the following warranty
code
7332 (OK) : Displays the date
of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial
Number
7832 (OK) : Displays (if found)
purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the
Purchasing Date MMYY
(Warning : You can only set
this once.)
Nokia 3110 Secret Codes 87267 (OK) : Transfers ALL
phone numbers, pictures,
sounds from one phone to
another
6232 (OK) : Displays the Month and Year of Manufacture
(0997)
This code is able to check,
activate or remove SIM card
restriction (SP-lock)
Use the * key to get the p, + and w chars
'Y' has to be 1,2,3 or 4 -
depending of what lock you
what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+3# for
Country-Lock status
#pw+1234567890+2# for
Network-Lock status
#pw+1234567890+4# for SimCard-Lock status # = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4 [Master Code] is a 10 digit
code, based on the phones
IMEI number.
[ No requests for the "Master
Code" will be entertained. ]
Nokia 3110 Secret Codes Eg. To remove restriction on
Lock 1 type following code:
#pw+(master code)+1#
If you just want to check your
phone use 10 random
numbers Eg. 1234567890 as the (master code)
eg. To check if phone if
restricted on lock 1 type the
following code:
#pw+1234567890+1# 1: Insert sim card of different
provider.
2: Turn on the phone and press
the UP VOLUME key for 3 sec.
then release it and the phone
says PIN CODE? 3: Press the "C" key
4: Then Press * and wait until
it disappears and appears
again, then press * one more
time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or
ACCEPTED) and the SIM card is
accepted until you restart the
phone again. NOTE: On version
5.04 Nokia has removed this
option. Fast silent mode
*#06# : Checking the IMEI
(International Mobile
Equipment Identity)
Sep 09, 2016 | Cell Phones
My imei no. is 354862026555404 i forget my security code plz plz plz give me a solution 2 unlock it....
HI
THERE ARE THE LIST OF NOKIA SECRET CODES ..
*#7780# Restores Factory Settings (Memory, language, counters are not included)
*#746025625# [*#sim0clock#] : Checks if the SIM clock can be stopped. SIM clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
*#3110# : Checking the phone's software (SW) - Also called "Firmware Revision Information".
Press the following warranty code
7332 (OK) : Displays the date of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the Purchasing Date MMYY
(Warning : You can only set this once.)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
6232 (OK) : Displays the Month and Year of Manufacture (0997)
This code is able to check, activate or remove SIM card restriction (SP-lock)
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+2# for Network-Lock status
# = DOUBLE-CROSS
Y = NUMBER 1 TO 4
[Master Code] is a 10 digit code, based on the phones IMEI number.
[ No requests for the "Master Code" will be entertained. ]
Eg. To remove restriction on Lock 1 type following code:
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
1: Insert sim card of different provider.
2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE?
4: Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again. NOTE: On version 5.04 Nokia has removed this option.
Fast silent mode
*#06# : Checking the IMEI (International Mobile Equipment Identity)
REGARDS
ANIRUDDHA
Sep 21, 2011 | Nokia 3110 Cellular Phone
Imei 35454001633758 i need security code
Jun 28, 2011 | Nokia 1110i Cellular Phone
Sir, plz give me phone restricted code my ime no.354862/02/440393/8
Just you try to check here to http://www.unlock-free.com/nokia/ or http://www.superunlockcodes.com/ this will be get you back to give the restriction code for your nokia 3110 at very short time..I also got the code from here only ...Hope its helpful...
Jun 28, 2011 | Nokia 3110 Cellular Phone
I hv nokia 2760 razor i lost security code cn u plz help me
You just use following links to get that code-
· http://www.giveawayoftheday.com/restriction+code+nokia+2700+2/
· www.unlocks.co.uk/enterrestrictioncode.php
· www.unlock-free.com/nokia-master
· http://www.syednetworks.com/general-nokia-secret-codes-for-all-phones
or
#7780# reset to factory settings.
*#67705646# This will clear the LCD display (operator logo).
*#0000# To view software version.
*#2820# Blue tooth device address.
*#746025625# Sim clock allowed status.
*#62209526# - Display the MAC address of the WLAN adapter. This is available only in the newer devices that support WLAN
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
May 07, 2011 | Facebook Apps
Lands Phones Logo
806 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
